How do you record FM radio on Sansa Fuze?
OK, while in radio mode, press the bottom of the wheel, scroll down to 'Recording', then select 'Record Now'.
(I have a Sansa Fuse too, so, i know my way around it.).
this should help.
Thank you for pointing me in the right direction. I was trying to figure out a friend's device and maybe some of the settings have changed a little since she just bought it 3 yrs after this post. I found that once in Radio mode, if it's the screen that shows just the current channel, then I pressed the center of the navigation area. The screen switched to the listing of available FM stations. I pressed the center of the navigation area again; then it listed options for recording, etc. Scroll to RECORD RADIO, then press the center of the navigation pad again. Recording will begin. Screen will now show the FM station and a running time for recording. It will also show an option to PAUSE or STOP recording. If you scroll to and select STOP RECORDING, you will be given an option to SAVE the recording before you exit. To play back a recording, return to the screen that lists the available stations, tap the center of the navigation pad, scroll to and select PLAY RECORDINGS. Once available recordings are displayed, you will also have the option to DELETE RECORDING(S) by scrolling to and selecting that option.
