Apple iPhone 4S Logo
L
Lonny Tucker Posted on Dec 19, 2016
I need to bypass the apple activation lock on my iphone 4s
5 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Apr 29, 2012
SOURCE: where do i enter puk code on iphone 4s
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
tickets1
phoenix kirkham
  • 641 Answers
  • Posted on Jun 13, 2012
SOURCE: iphone blocked by apple
yes..contact www.phoenixtec.org or .ca, they have the smarts to help you
fullbar_28
edwin botio
  • 624 Answers
  • Posted on Oct 02, 2012
SOURCE: Unlock iPhone 4s to AT&T network
hi ,you need to factory unlock your phone...please post your IMEI number so we can see if what is the carrier...you pay a little bit money to unlock it..
jarad493
Jarad Thomas
  • 33 Answers
  • Posted on May 16, 2013
SOURCE: DOWNGRADE my iPhone 4S
u cant downgrade unless your phone is jailbroken AND you have the SHSH blobs for 6.1.2 saved
Anonymous
  • 4 Answers
  • Posted on May 24, 2013
SOURCE: Iphone 4s shins
Step 1: Clean your workspace. Be sure to get a flat, hard surface without a lot of fabric, liquid, dust, etc.
Step 2: Lay the phone down and clean it well with the cleaning cloth provided. Do not use any kind of cleaning fluid or water, but try to be sure that all fingerprints are gone. Especially be sure no dust or lint particles are on the screen. Before proceeding be sure that there are not a lot of dust particles gathering near you, vaccum and clean the area up a bit more if need be. You want as sterile an area as possible before continuing.
Step 3: Being careful not to touch the sticky side of the screen protector, peel back the tab where indicated. Hold the screen protector only by the sides and line it up with the phone. If you touch the sticky side of the screen protector by accident do not try to clean it off, you will only make it worse. Line up and let the screen protector fall into place from the top of the phone to the bottom. Some people choose to use a credit card or thin piece of plastic to smooth out bubbles as the screen protector makes contact with their device, however this is usually not recommended by the makers of the screen protectors or the phone. The choice is yours, but bubbles are meant to smooth out over time, so take that into consideration.
Steap 4: Once the screen protector is on the device if it is straight and you can see bubbles but no lint or dust beneath it, you are successful, give it a few days for the bubbles to dissipate. If it is not on straight, you may be lucky enough to be able to lift it up and place it better without fault, however this is risky. If lint or dust has gotten between your phone and the screen protector you have likely failed, there is little recourse from here, other than removing the screen protector, cleaning the device, and trying with a new screen protector altogether.
2answers
How do i bypass the apple id activation on my iphone 6?
iCloud Locked iPhone 6 How to bypass iCloud Lock on iPhone 6
So, in this post, I would like to show you 4 solution about iPhone activation bypass
Solution 1. Remove iCloud Activation Lock from your iPhone 6 with Unlock Tool
Solution 2. Bypass iCloud Activation Lock Software via iCL0udin
Solution 3. Bypass iCloud Lock via Apple Setting
Solution 4. Bypass iCloud activation online with iCloud Lock Removal Service
Sep 19, 2016 • iPhone Apps
1helpful
6answers
I need to unlock icloud locked iphone
My iPhone is locked by iCloud, and I have seen many tutorial videos and they recommended this page to me https://bit.ly/2DbIzGu and I could not do anything I can do?
I started setting it up and had to charge it when I went back to finish so I can have it activated it has pass code on it. How do i get the pass code off ?
Hi Angel, The two links below are youtube videos showing how to bypass iphone password lock, Also there's videos down the right side that may help as well...........CHEERS..
How to unlock any iphone without password
How To Bypass Any iPhone Passcode
6helpful
4answers
How would i remove i cloud from a phone i bought and owner no where to be found
There is no known way to bypass an iCloud unlock unless the previous owner provides the correct credentials for the account in question. Performing a factory restore will not remove the lock since the lock requires authentication through Apple's servers. Hypothetically even if you could restore the device to a previous firmware, the lock will remain.
How to bypass iphone 4s activation screen
there no way on ios7 u can bypass activation there is no solution at this time
How can i jailbreak iphone 4s that has find my iphone activation lock?
contact the seller, ask him/her. Check the merchendise before paying. Don't buy stolen phones.
IPhone 4s switched not active
Phone wasn't correctly unlocked then, you need a sim from provider...lets say like ATT, when you hook it up to Itunes it will find IME sim card and place the unit in active status if it was approved to do so, any further questions I will assist you.
1helpful
Apple i phone 4s sim unlock code telus
Hi, You can unlock an iPhone 4S locked to Telus network using remote unlocking service. This method of unlocking is safe, simple,. affordable and quick. you can get the remote unlocking for an iPhone 4S from www.prounlocking.com/apple-iphone-4s/rs16wp9/ at affordable cost with easy instructions on unlocking. This method of unlocking also doesn't require a Jailbreak too.
UNLOCKING STEPS FOR AN iPhone 4S
1. Wait for us to send you an email saying your phone has been activated or remotely unlocked.
2. Install the latest version of iTunes.
3. Make sure your Apple iPhone 4S phone software is updated to the latest version using the iTunes software.
4. Connect your Apple iPhone 4S to iTunes with a NOT ACCEPTED SIM card.
5. Wait until iTunes detects your Apple iPhone 4S.
6. Disconnect your Apple iPhone 4S and reconnect it after 10 seconds.
7. Your Apple iPhone 4S is now unlocked.
Oct 31, 2012 • Cell Phones
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
