20 Most Recent Apple Iphone 4s I Phone 4 S Factory Unlocked Sim Free 16gb - White Questions & Answers
3answers
How do i use down load music for my ringtone
it is a long process. if you are up to it this is a pretty good guidehttp://technologyguy.hubpages.com/hub/Convert-iTunes-music-into-ringtone-for-iPhoneit is most definitely easier to get one of the free ringtone maker app for you phone. just know that most are going to limit you to 30 - 45 seconds of the song. good thing about it is that you can choose which portion of the song you want
8/26/2021 2:41:25 AM • Apple Iphone 4s... • Answered on Aug 26, 2021
2answers
Can not get i tunes app to show up for ringtone
if you are trying to create a ringtone in iphone you must use itunes in your pc to extract the ringtone to your iphone.
4/23/2021 2:30:00 AM • Apple Iphone 4s... • Answered on Apr 23, 2021
2answers
Why is my iPhone 4S not storing pictures & videos when snapped & recorded ?
Could you be out of memory? Check how much you have by going to Settings>General>About>Available.
2/27/2021 2:06:31 AM • Apple Iphone 4s... • Answered on Feb 27, 2021
Http://filesmy.com/file/0Rh5c
LOL
4/10/2019 7:29:18 AM • Apple Iphone 4s... • Answered on Apr 10, 2019
3answers
Newnew
Contact the original carrier and see if youre illegible and they will take you from there!
9/11/2017 10:29:28 AM • Apple Iphone 4s... • Answered on Sep 11, 2017
3answers
How do I remove pass code
Settings>Passcode>Turn Passcode Off
3/16/2017 5:31:46 PM • Apple Iphone 4s... • Answered on Mar 16, 2017
2answers
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
12/27/2016 6:38:18 AM • Apple Iphone 4s... • Answered on Dec 27, 2016
Reset forgotten password
You will most likely have to restore your iphone through itunes. You can do this but the only draw back will be losing any apps, music and contacts that are not saved or backed up through your itunes account. If you want to restore your iphone which is the only way you can bypass your passcode, you first need to connect your Iphone up to your itunes account through a laptop or PC. After the computer connects up to your phone, first press the power button and count to 3 and keeping the power button pushed in press and hold the home button. Keep both buttons pressed in until the iphone goes into recovery mode and than release both buttons at the same time. It may take 30 seconds. You should be able to restore your iphone and than you will be able to put in a new passcode. If you put it into recovery mode and you change your mind don't worry, just press and hold the power button until the apple symbol appears and than release it and it will take you back to the locked screen.
10/12/2016 3:41:46 AM • Apple Iphone 4s... • Answered on Oct 12, 2016
How to unlock the activation lock on my i phone 6 plus
Factory reset the phone .
10/10/2016 11:32:41 AM • Apple Iphone 4s... • Answered on Oct 10, 2016
0answers
2answers
How do i unblock cookies in my i phone
Find your Settings, look for Safari setting, there should be an option to Accept Cookies. Tapping it will allow you to set either "Never", "From Visited", or "Always" If you need further help, reach me via phone at https://www.6ya.com/expert/paul_0c66f8a4b832f53f
9/15/2016 4:22:47 PM • Apple Iphone 4s... • Answered on Sep 15, 2016
[email protected]
Make sure that you are using the same computer and icloud account when doing this. Also if on the cloud just sign in to it on the new phone and all things that you have synced should be synced. iCloud Use iCloud com
9/10/2016 12:53:25 AM • Apple Iphone 4s... • Answered on Sep 10, 2016
Why is daughter not receiving texts in Malta from me
It could be that her roaming it set to off. This would not have the iphone connect to cell towers there. Also could have to do with imessage or many other things more info is needed. Also turning on data roaming will add a fee to your bill so be careful and use at your own discretion. Use cellular networks on your iPhone and iPad while you travel...
9/10/2016 12:51:08 AM • Apple Iphone 4s... • Answered on Sep 10, 2016
Im trying to down load the paypal app on my iphone 4
Hello Patricia. I was looking at the web searching for a solution to your problem, or if anybody else have got the same problem. According to Paypal website, the app is suppose to be compatible with your phone model. Paypal for IOS support IOS 8.0 and up. Ifyou still can download the app I do suggest that you visit the Paypal forum @ https://www.paypal-community.com/t5/US-PayPal-Community/ct-p/US
7/11/2016 3:16:22 AM • Apple Iphone 4s... • Answered on Jul 11, 2016
Have an i phone 4 trying to clean it as i forgot the code can you help me
Connect your iPhone to iTunes on your laptop; While your iPhone is connected, force restart it: Press and hold the Sleep/Unlock and Home buttons at the same time. Don't let go when you see the Apple logo - keep holding until you see the recovery mode screen. Then when you get the option to restore on iTunes, select that. Hope this helps! If you forgot the passcode for your iPhone iPad or iPod touch or your...
6/21/2016 8:41:28 PM • Apple Iphone 4s... • Answered on Jun 21, 2016
2answers
IPHONE 4S CARD NOT SUPPORTED HOW TO GET THE CARRIER
There is more than an issue to cause this. 1st that some iphones are locked on a specific operators, with a contract for one or couple of years. after end of contract you can unlock the iphone at the operator and can use any sim card. 2nd the sim card it self may be damaged & cannot be read by iphone, please try it in another phone and see if it is working. To know if your iphone is officially locked/unlocked by the model number, you can google it.
5/19/2016 5:47:20 PM • Apple Iphone 4s... • Answered on May 19, 2016
How big is the handset?
https://www.apple.com/lae/iphone-4s/specs/ Height: 4.5 inches (115.2 mm) Width: 2.31 inches (58.6 mm) Depth: 0.37 inch (9.3 mm) Weight: 4.9 ounces (140 grams)
5/19/2016 6:13:45 AM • Apple Iphone 4s... • Answered on May 19, 2016
Apple Iphone 4s I Phone 4 S Factory Unlocked Sim Free 16gb - White Logo
279 questions posted
Popular Products
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Apple Cell Phones
  • Apple Cell Phones
Most Popular Question
iphone 4s card not supported get carrier
  • Cell Phones
