SOURCE: No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
SOURCE: HDMI ports will not work
Unplug the tv,satalite box and playstation 3,replug all the devices about an hour later.Go in ur tv menu,goto PICTURE,go down to reset the Tv Tuner board,will reset the tv Tuner board will reset it back to factory setting.Than still have the same problems.The tv Tuner board it dead,require the Tv tuner replacement.
SOURCE: My Samsung UN55c7000 does not
I'm sorry for the difficulties you're experiencing as the HDMI port on the TV is not working as expected. Please follow the below troubleshooting steps and check the operation.
Thanks for understanding. Please let me know the result after performing the steps.
