20 Most Recent Samsung LE32R74BDX 32 in. HD-Ready LCD Television Questions & Answers
ur tv needs a new ip board u can remove the back panel and its the center main board it'll be obvious to plain site being its the only unprotected board in the tv. get the model number from the top left of the part then go to samsungparts.com enter the part number order the part.this part is only about $130-$150 dollars and ur tv should be as good as new. the ip board is a simple fix just six screws around the board and seven wireharnesses just remove insert new part and and reconnect wire harnesses to correct slot that u removed them from screw back down and ur all set no big deal. dont ask samsung or a repair man they'll just screw u over and throw u around about ten differetn loops. not gettn a straight answer other then bring it n and charge u about $600 to fix. i see alot of people have this problem so there u go simple fix guaranteed. u r welcome.
Samsung... | Answered on Dec 16, 2019
Hey it taken me a few years to find a solution to this problem.
I also own a Samsung syncmaster 2032mw.
BTW you must hold / use the "Menu key on the side of the TV", as holding the remote key dosen't work!!
Many thanks dopeNL
Samsung... | Answered on Nov 26, 2019
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Samsung... | Answered on Nov 05, 2019
hi there...is very easy to get manual for your samsung...just write the type of your samsung (ex: Samsung LE32R74BDX HDTV 32 inc) go to samsung website..choose support/download. find your tv model and if there manual download as pdf you can download to your pc.
or if you want to know speck of your tv go to product line and find your model tv and press enter they will show you the spek of your tv...
Samsung... | Answered on Oct 31, 2019
The problem is called pixel retaining, you need to replaced the LCD panel, no way to fix it.
Samsung... | Answered on Apr 14, 2018
Your universal remote control may have several codes available for different functions.
Samsung... | Answered on Dec 25, 2017
Unplug TV, take off the back. One each board there will be capacitors. the tops are flat unless one has blown then it is bubbled up. If you find one that is bad, copy the number and search the internet for a replacement. Unsolder and remove the old one ( there is a line drawn on the negative leg, mark the neg side on the motherboard so you can replace the new one the same way). Now solder the new one back onto the board. This worked for my TV, hope it helps
Samsung... | Answered on Jun 01, 2017
Unpluging the set for about fifteen minutes or to see if that helps, if that doesn't do it, then it is your power supply board.
Samsung... | Answered on Mar 25, 2016
Jan 2016 --- Panzo's solution worked a treat, just remember to go into analogue, press buttons quickly, navigate to reset (option#12) and press left arrow which will remove the snow effect in analogue.
Thank you, and the rescanning worked without a hitch. Whew thanks again
Samsung... | Answered on Jan 07, 2016
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Samsung... | Answered on Nov 30, 2015
When the screen flickers on and off it usually comes from the power supply or backlight inverter being bad. For your TV, the backlight inverter and power supply unit are combined. As you can see in the picture attached it's the white part on the right side that has gone bad. You will need to replace that board. LN40B550K1F Samsung LCD TV Repair Guide
Samsung... | Answered on Feb 12, 2015
Check for swollen capacitors on the power supply board.Very common problem on samsung lcd tv's.
Samsung... | Answered on Jan 10, 2015
remove the rear panel and the lit area with clean dry cloth
Samsung... | Answered on Aug 28, 2014
I had the same problem. Had to connect using the composite cable, when to settings, changed it to HDMI. This turn the display on my TV off again. Then plug in the HDMI and it worked!
I also expected it to be plug and play... Hope this works for you...
Samsung... | Answered on Aug 21, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Samsung... | Answered on May 03, 2014
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
211 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
samsung tv le32r74bd standby light but
  • Televison & Video
