If the light your referring to is the indicator for the bucket to need emptying , this is a very common fault to have on lots of dehumidifiers , its caused by the float sensor in the bucket to b slightly out of place , as it senses using a magnet to trigger a hidden switch , id look carefully at float and id bet its just not exactly right sitting in its slot to pivot on
Testimonial: "Sorry for the miscommunication. The Essick 1208 is a Humidifer, not the opposite. It keeps telling me to fill it, then it turns itself off, even though the reservoir is full. I have replaced the filters and cleaned the unit thoroughly. I am suspecting a sensor.."
One more comment: I went ahead and bypassed the micro-switch that transmits the float message of F. Now it works perfectly. .... (success)........
How did you bypass the micro-switch? I'm having the same problem.
I had the same problem. I took an index card to make the switch area larger. Just fold an index card tape and slide over the switch contact area. Bad design on this.
I ended up getting the unit disassembled, and then jumpered out the microswitch. I wanted to install a new one, but the Essick company would not sell it separately.
