Posted on Dec 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My epson artisan keeps restarting over and over. UPDATE: I tried all kinds of stuff. Finally I decided to hook it up to the network the old fashioned way, with a cable.
All of a sudden this morning my Epson Artisan keeps restarting. It starts up and goes through the warm up process and restarts. Unless I turn it off it will do this forever. UPDATE: After connecting to the network with a cable, I turned off Wi-Fi on the printer the next time it started up. You will only have a small window where the navigations work so go to the "Disable Wi-Fi" screen and it will tell you "Starting up. Please wait." Just keep pushing the Disable Wi-Fi Button until it asks "Are you sure you want to disable wi-Fi." Then say yes, and your problem is fixed. I am going to look into my router's firmware and see if there is an update that just happened because until this morning, this has been on 24/7/365 and not one problem. I will also check Epson"s site to see if there are updates but there hasn't been any for years, but I will check to be sure. If any of that fixes the issue, I will update this post for the benefit of the rest of you with this printer or any wi-fi enabled printer for that matter. I doubt that the Wi-Fi capability, software, drivers, etc are Epson's anyway. Thank God this is fixed. I wish all of you a very Merry Christmas and remember that Christmas starts with Christ!!!
CheckitRight
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Epson Master 1,363 Answers
  • Posted on Dec 06, 2016
CheckitRight
Epson Master
Level 3:
Renaissance:
Answers
1363
Questions
Helped
646895
Points
2795
I've seen this on HP printers, try to delete any prnt jobs then restart the printer
Testimonial: "There are no print jobs. I have restarted the router, waited for it to come back up completely then plugged the printer back in. It has been working for a long time without an issue until this. I called Epson and waited for 2 minutes for someone to answer. The guy asked me to turn off the router again which I forgot disconnects my VOIP phone. They have my number but of course they don't call back. That would be Customer Service. I can't find anything googling it either. I have disconnected everything and lifted the scanner and put it. Back down, replaced $90 worth of ink cartridges and it still does the same thing. Thanks for trying though."
  • 4780hb Dec 06, 2016
    That was supposed to be 28 minutes on hold. Also, the printer had been unplugged for over an hour while I went to the start and got $90 worth of ink. The print job cache would have been cleared by that alone. I have 30 + years working in IT, so I have a little knowledge. Thanks again for trying to help.
    Spell checker keeps changing words after I press the button to submit my comment. It should be store and not start. Sorry folks for the unreadable sentences.
How can reset epson artisan 730 using ssc service4.30 in winddows 7/8
Download WIC Reset Utility - Free - 2Manuals.com
www.2manuals.com > ... > WIC_RESET
Operation Systems: Windows XP, Windows 7, 8, 10, Mac OS ... THE WIC ResetUtility WILL RESET Your Epson Inkjet Printers WASTE INK COUNTERS ... 700, Artisan 710, Artisan 720, Artisan 725, Artisan 730, Artisan 800, Artisan 810, Artisan 830, .... Q.: If I buy 5 RESET KEYs I can use them for different printer models?
WIC Reset Utility - Reset Epson printers Waste ink Counters
wic-reset-utility.blogspot.com/
Oct 5, 2014 - Artisan 720.725\Artisan 730\Artisan 800\Artisan 810\Artisan 830 .... If I buy 5 Reset Keys CAN I use them for different printer models? .... The Windows 7 WICReset Utility - for Waste Ink Pad Counter reset - Service ... Reset epson printer protection counter using ssc service utility, reseter epson r220 [...]
Printer Manual: SSC Service Utility for Epson Stylus Printers
printermanua.blogspot.com/2014/.../ssc-service-utility-for-epson-stylus.h...
Feb 22, 2014 - Problems with Epson printer, the red and greenness lightheaded ...
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
My Epson Artisan 730 Printer keeps ejecting its CD/DVD Print tray, saying that there is a cd there. There, of course isn't. Can anyone help me? I really need to print.
My husband adjusted the CD/DVD tray, then we selected the icon that looks like a wrench on the printer's message window, then "restore default settings" on it. Turned computer off then on again, and it FINALLY started working again :)
My lacie 2big network 2 is not often found on the network during these two last week, Note that it was ok for the 5 pasts month. Today the same thing happen, after waiting for several minutes i restarted...
this unit does have some issues with the auto update. It was a good move of you to backup the data on it.
Sometimes, moving to another section of the administration webpage and coming back to the update section will take you to the next step, or you will have to start the update again.
Another option, is to download the capsule file to proceed with the update. It is available on the LaCie website if you are patient enough to find it in the list (look under hard drive downloads)
If the update process still is not working with it, you will have to reboot.
As for your lack of connectivity, it is sometimes caused by the load of the unit, so maybe you can try to make sure the unit is not used beyond its abilities.
If you see no progress. Please provide me with your operating system and the current version of your firmware.
Regards,
13helpful
3answers
My artisan 700 keeps pilling in multiple sheets and then jams.
hi there, il be glad to assist you.
If multiple pages feed at once, remove the paper from the tray, fan the edges to separate the sheets, then reload it. if Paper Jams Inside the Artisan 700 Series: Open the scanner. Remove the paper as shown, including any torn pieces. Squeeze the hooks and remove the cover inside the Artisan 700 Series. Remove the paper as shown, including any torn pieces Reattach the cover. Close the scanner. if after doing all of these still same issue persists, if the issue persists, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
1helpful
Hooking up Epson Artisan 800 to wireless. Get all
You must set both devices to the same encrypryption protocol, WEP or WPA. That being said, I had to setup my router using WEP - the printer refused to connect via WPA. Good luck.
I keep getting the error message ''EEventManager has stopped working.'' when i try to scan on my brand new all in one printer. How do i fix it?
uninstall the previous version of event manger and install this copy -
http://www.epson.com/cgi-bin/Store/support/Supportdlsurvey.jsp?BV_UseBVCookie=yes&download=ftp%3a%2f%2fftp.epson.com%2fdrivers%2fepson13161.exe&pn=Epson+Artisan+710&pc=Epson+Artisan%26%230153%3b+Series&ft=software&returnpage=%2fsupport%2fsupDetail.jsp&returnparams=%26infoType%3dDownloads%26oid%3d132633%26prodoid%3d63084663&licenseoid=17774
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
