SOURCE: Konica-Minolta Dimage Z2 can't turn on
Well, I also bought the DiMAGE Z2, and my problem was similar: It worked for some time, but then it started freezing sometimes, not responding to any button I pressed. One time, it froze, shut off, and I wasn't able to power it up again. In short, the camera was still under its warranty, so I gave it to their lab and they fixed the problem.
SOURCE: Camera shut down
Hi the problem your having is that a component on the board isnt letting the correct power come from the battery therefore giving false reading on the batt display the huge problem you have is that they dont repair these cameras it just isnt financially worth it so unless you know how to test all components on the board the chances of getting it reapired are slim to none their isnt anything you can do as it is a board problem.
If you tested the battery and this is fine then the problem is deffinately with the board.
How long have you had the camera if its not long then i would get a refund as repairing is something they wont do sorry i couldnt help you any more but other experts will tell you the same
SOURCE: Konica minolta Dimage x50 doesn't work
Buy the AC adapter plug the camera in without any battery, if it works then its the battery,if not its the camera.
SOURCE: suitable compact disk memory card for dimage a200
I have the same camera. It will use up to a 4GB card as standard and up to 8GB with the correct firmware.
Check the following web address for further information: -
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-a/dimage-a200/software_drivers/firmware/installation_guide.html
I hope you find that my answer has helped, if so please return the favour by rating my answer.
SOURCE: minolta dimage g400 camera...cannot get the lens to close
Your problem is likely due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
