Cars & Trucks Logo
Eve Skinner Posted on Nov 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Electrical/Security problem Buick Rendezvous 2002-Different dash lights on, dinging, lights won't turn off.
Back window behind driver side fell straight down to bottom of door off of track; drove home fine, put plastic/tape on window until it can be looked at. When I turned off car, it started dinging constantly and different lights flashed on dashboard (security, error, low brake fluid, and door constantly ajar (all doors were shut). Left car for 10 minutes and it all stopped, but I assume it will do this next time I drive. Any way to reset it?
Lawrence Oravetz
Level 3:
  • Buick Master 10,558 Answers
  • Posted on Nov 29, 2016
Lawrence Oravetz
Buick Master
Level 3:
Answers
10558
Questions
Helped
2700612
Points
29284
The body control module controls all of your freaky problem. Replace that.
I pulled a fuse while Buick was running car died now wont start
disconnect the battery and seee if that resets the computer
2002 Buick Rendezvous Driver's Side Climate Control does not blow out heat
Could be a sensor or one of the blend doors under the dash.
You may need a shop manual to get the troubleshooting procedure.
2002 Buick Rendevous intermittent electrical issues
Classic description of a fretting issue. Read this post on the issues GM has with fretting.
Fretting corrosion in electrical contacts Ricks Free Auto Repair Advice
I have a 2002 Buick Rendevzeous. Sometimes the driver side low beam works, sometimes it doesn't. When it doesn't, the turn signal won't blink. It just stays dimmly lit. Right now, the low beam...
You have a bad electrical connection. Check the wiring harness and both sides of it's connectors for corrosion and or breakage. The connector terminals will become worn and corroded and the wiring sheaths a prone to weathering and become brittle. Replace or clean as needed.
2answers
My inlaws' 2004 buick rendezvouz: the dash lights don't come on. Dealer says no dash lights were installed on that model. Chris
The dealer is blowing smoke up your tailpipe. I couldn't find a manual for the '04, but the '03 and '05 have identical controls for the dash lights, so it's a very good bet the the '04 is the same. Here's a link to the manual for the '05 -- you will find the dash light control on page 3-16.
http://www.extendedgmwarranty.com/owners-manual/buick/2005-Buick-Rendezvous.pdf
P.S. You might want to print the page and confront the dealer with it . . .
2helpful
Replace fuel filter 2002 buick rendezvous
it has a plastic filter on the drivers side behind the drivers door underneath the vehile you will needle nose pliers a rachet with extension and 10 mm socket
The driver side window will not come back up. the
I have this problem in my Buick Park Avenue. The two passenger side windows and the driver window work fine, but the rear driver side window won't close if it's opened. I disconnected the wire from inside the door to avoid further problems.
First try helping the window up, by gently pulling on it while you push the button. If this doesn't work and your vehicle is still under warranty, take it back to the place of purchase, the window motor will need to be serviced or replaced.
Buick Rendezvous Window Motor
3helpful
3answers
My 2002 buick rendezvous radio lock came on and my dash lights will not come on now
my radio and power options wouldnt work and it said security. My boy friend disconnected the battery cables and quickly rubbed the positive and negative ends together which rebooted the computor. I do not know if its good for it or not but it definately worked my power options are back.
1helpful
Security Light on and gauges now not working
has anything been done recently to car. sounds like you have a short either burnt up wiring on the power side posible fuse block under dash, or wiring going to your security module,
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
