I've got the Alarm 1 set for weekdays at 4:45 AM. It goes off at 4;45 Pm--even tho' the clock reads AM.
Sorry it took so long to answer your question about the Clock/Radio. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Travel alarm clocks can have varying
instructions, depending on the type of clock you are using. Here are
some tips for use that will apply to any alarm clock.
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
How do I know how to set for am or pm for the alarm
alarm goes off in am and pm when set to am only
