Replaced spark plug and like i said starts and runs without cover and filter - dies if i put cover - sans filter - back on and will not start unless i remove cover.
SOURCE: Craftsman 19hp riding mower wont stay running
The carb jets are partially clogged and needs to be cleaned.
SOURCE: craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
SOURCE: Starts and runs until it gets hot.
Hello:
Your Problem can be Caused by Several Possible Items.
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
>>Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: 10 year old Craftsman Lawn Tractor won't start
I had a similar problem and found that the float was hanging up on the wall of the carb fuel chamber. I sanded lightly the outer edge of the float and never had the problem again. That was 3 years ago. Having a different problem now. After setting overnight in cold weather, 20's, engine turns over very slowly even with a new battery. Engine starts, but barely. Once running, everything seems fine. After shutoff, engine restarts quickly. Next morning, same thing happens. Anyone have any thoughts?
