Ive tried doing a hard reset on my device, and ive tried several methods but none work. I tried the recovery options but it says Insert your Windows installation or recovery media, and restart your PC with the media. doesnt work i tried backing it up with my usb drive but it doesnt let me.
SOURCE: My recovery CD (gateway 7330gz PC) are no working
I have the same problem with my Gateway 7330gz. My laptop got infected with spywares and it was so annoyed that I have to think about recover the system. So I did it with Gateway Recovery software. I chose the recovery option (press F11 when boot up)from hard drive since my dvd drive was broken. It went well but when it boots up again and Windows XP says detecting and installing the drivers and such, it was frozen haft way through. I turned off power many times to reboot but it kept freezing at that point. I search Internet for help and seen this post. Wonderful! I press F2 to go to BIOS setup screen, use right arrow key to move to Advance menu option. There I use down arrow key to select SpeedStep, hit (-) key to disable it. Then F10 to save and exit, hit enter for OK button. The system boots again but this time it was no longer freezing, the setup process went through ok and continues...I am so happy and type this message so it might help others with the same issue. Thanks
SOURCE: HP Pavilion Dv5-1008TU Hard Disk / Hard Drive not detected.
The hard drive test could not detect the hard drive, indicates a faulty drive.
Also if the drive does not spin up or is making clicking sounds then the it is definitely faulty.
You need to buy a new drive.
SOURCE: No audio output device is installed on hp pavillion dv6000
First go online go to HP site and go driver download and puch in the the Product no of your PC it will bring up the entire list of drivers for your PC. Now you need to do a BIOS update than restart the PC. it should work fine and the pop up should not come anymore.
SOURCE: windows has encountered a problem communicating
There might be a problem with your hard disk since the recovery disk does not work. Replacing the hard disk would fix the problem.
