This mentions checking the motor, and certainly could be generated from the lower control board. I recall these controllers as quite large with maybe 4 to 8 large storage capacitors on them, which do fail over the years, and could cause this. Does the tread run at all? Error right away or move the belt then error?
If you wish to get some details about treadmill repair and error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Replace the the Fuser film in the fixing unit....
Clear the error and restart the machine problem will be solve....
The white mark of the fuser film on the right side replace properly if you insert reversely same problem will be persist..
I got dkcity treadmill model number- DK5320HRP ' When we press start button the motor does not turn and after few second an error E7 showing on the display. plaese if anyone can solve this proble
1) You must check the receptacle is there are Voltage missing.
2) You must check in according with Treadmill is the machine operate in 115V- or 220-Volts AC, 60 hz.
3) You must use some VOM, for the check the voltage if you can not operate the VOM, you must check the plate in the Treadmill what voltage are using 115 or 220V, you can use some Lamp for table tha work with 115 Volts, for to proof. If the lamp doesnot light,some Breaker or Fuse is Open. Check the circuit closing the Breaker or replacing the fuse.
4) After you checking what voltages are using , you must conclude if the voltage in receptacle is o.k or improperly in according with the voltage of the Tradmill.
5)If the Voltages are O.K you must check in the Plug is some wire is loose, or contacts corroded.
6) Must check to the wire is broken from the plug .Replace or repair.
7) Check is the fuse or breaker of the machine is open. Replacer or testing again.
8) If there o.k You must check the rely or contactor from motor, if that corroded or dirty, for to clean or replace .
9) Check finally the motor , if work in 115 or 220 Volts,maybe some Animal byte the wires, and open the same, Replace the wires or repair.
This is most unfortunate if this either club track 510 or 612 your out of luck the electronics are no longer available. If these are either 510 or 612 you can get it repaired call National Gym Supply @ 1-800-496-7278
