Samsung 65"LED i have sound no picture, if i unplug TV the pictures and sound come on but when i turn TV on some time no picture Bad T-con board?
Perform a Flash Light test to confirm you panel and inverter states. LCD LED TV Repair No Image Blank Black Screen Flashlight Test How to Fix...
SOURCE: Samsung LNR408DX/XAA Powers on with sound but no picture
I think you need to exchange the Main Board.
SOURCE: Samsunb 4051: TV screen turns off sound stays on.
Most likely this set has an "integrated" inverter, as most samsungs do--and this DOES sound like an inverter problem. Make SURE thought, there are no more bad "10 volt" caps on the power supply...ALL of them need to be replaced no matter HOW they look.
SOURCE: tv turn on no pic or sound
I bought a tv form china, which model is LG 42sal80yd-ca. i was update firmware dtv v3.15 epk.then its restart and it does not on, only power light on and black screen the it off automatically, not its on and off continue. please help me
SOURCE: my samsung tv model number
This is a plasma screen T.V. and doesn't use a lamp. You are probably correct in thinking it's the T-Con board. This board is sometimes a pain to get it. When you get to the board, look up the board number on the side on e-bay or other internet resources for the lowest price if you're comfortable changing it yourself.
SOURCE: How does a T-con Board works?
It is difficult to type in all here by this window, as it is too much. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
