Amazon Kindle Fire HD Logo
garymullen54 Posted on Aug 18, 2016
Music will not load when I tap the icon?
Recent activity wording appears in the left hand corner, but it won't load up music?
1 Related Answer
jeicrash
Jeff richtman
  • 324 Answers
  • Posted on Nov 17, 2014
SOURCE: I cannot get back my stuff on my kindle. It is on Kid Stuff;it WON"t go away.
The kindle and most other tablets allow multiple profiles to be setup and used by several people.
Try swiping your finger down from the top of the screen, you should see "Parent Settings" If you set a password you can input it here then pick a new profile to switch to.
If no password was set, you should simply be able to switch profiles.
Stop tablet saving recent windows across boots
To stop your RCA Viking tablet from saving recent windows across boots, you can try the following steps:
  1. Go to "Settings" and select "Developer options".
  2. Scroll down to the "Apps" section and select "Don't keep activities".
  3. This option prevents the device from saving recent activities, so they won't appear when you reboot your tablet.
Alternatively, you can try using a "one tap closes all" button app from the Google Play Store. Some popular options include "Task Manager" and "Advanced Task Manager". These apps allow you to close all open apps with one tap, which can help to prevent recent windows from being saved across boots.
tip
How to Remove Songs from iPad in 3 Ways
Part 1. Delete Individual Songs from iPad
Step 1. Launch the Music app on your iPad.
Step 2. Tap "Songs" on the bottom to see all of the music on the device. Choose the individual track you want to delete and slide your finger to the left across the songs.
Step 3. Tap on the red "Delete" button to remove music from your iPad.
Part 2. Delete All Songs from iPad
Step 1. Go to the iPad's homepage and tap on "Settings" icon.
Step 2. Tap "General" > Select "Usage" > Choose "Music." The iPad will display how much space is taken up by music on your device.
Step 3. Tap "Edit" button on the top-right > Tap the red icon next to All Music > Tap on "Delete" to remove all songs from iPad.
Part 3. Delete Selected Songs from iPad with AnyTrans
AnyTrans is an all-around iOS files manager that made to transfer and manage all your iPhone, iPad, and iPod content, such as, music, videos, photos, contacts, notes, messages, apps, etc. You can freely add or delete songs from your iPad with AnyTrans.
Step 1. Download and install AnyTrans on your computer. Run it, and connect your iPad to computer.
Step 2. On the homepage of AnyTrans > Click "Audio" > Select "Music".
Step 3. Highlight the songs you want to delete and click the trash icon on the top-right of this window to delete the unwanted songs.
Resource from: How to Delete Music from iPad
How to Delete Music from iPad in Three Ways
Have echo and new apple i pad how do i install it to get wifi. i have 0 knowlwdge
Follow the small sheet of instructions that came with the ECHO.
if you want to hear music (and other audio) in stereo, attach a separate pair of stereo speakers to the 3.5 mm jack on the back of the ECHO (I'm assuming it has one like my Echo Dot does).
you may have to push the 3.5 mm plug in hard for it to connect to both stereo channels on the cable. If you only hear sound out of your left speaker, both channels aren't connecting. Disconnect and reconnect the 3.5 mm cable a few times, being sure to push it in hard. This will loosen up the jack so that the plug connects easier and correctly.
On your iPad, open the App Store by tapping its icon.
in the search box at the top, type Alexa.
From the list provided, click the Open button next to the icon for Amazon Alexa, and follow any instructions that may follow. The icon should appear on you iPad, most likely on the last screen of icons (assuming the you have more than one screen of icons). Sweep to the left until you get to the last screen of icons to see it. Then click on the icon to open the app. When the app opens, click on the "3 horizontal bar" icon in the upper left corner. A menu will drop down. Click Settings. Then, click SET UP A NEW DEVICE , and follow the instructions.
How do I delete music from my ipad
Method 1. How to Delete Individual Songs from iPad
Get another two ways in this guide: https://www.imobie.com/support/delete-music-from-ipad.htm
How do I delete music off my tablet?
Use the icon for files and folders. Navigate to the music folder, use the menu and tap select, tap all or the music u want to delete and tap delete from the top menu.
How do I delete Facebook from my Ipad
If you find the Facebook icon, tap and hold down on the icon until it starts to jiggle around. Then tap the little 'x' on the top left corner of the Facebook icon. A message should appear asking you if you want to delete Facebook. Press delete.
3answers
How do i remove down loads
to remove downloads from tablets and ipads press on the icon for a few sections until they start to shiver and a delete x will appear press that and it is deleted press the stop/start button to get back to normal
How to delete unwanted music
is it a galaxy samsung tablet ?
in apps find an app labelled as my files with a folder icon above it
under root/sdcard/music
find music file click on the little box left of the file you wish to delete
a green tick will show in the box
once you do that you will notice at the top of the screen a dustbin icon has appeared in the right top side. press this icon to delete the file. then click on yes when it asks if you want this item deleted.
Then double click back icon to get out of my files
back icon is bottom left corner on black part of screen.
2answers
How do I download music from my Microsoft surface pro 3 tablet? I tried but I received an error code 43.
Please explain what device your trying to download too?
Can I guess these are some sort of music files like .MP3? Does your MSP3 have a USB port or a storage card like a mini SD? If so use it to transfer.
1helpful
2answers
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
