9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal Charger Power Supply. AC Input 100V-240V 50-60Hz;DC Output. Industry Quality : Over Voltage Protection, Over Heat Protection. Brand New Adapter, 100% Compatible. Warranty:1 year warranty, 30 day money back guarantee. Shipping from USA !
Accessory USA 9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal Charger ... D'Addario Accessories PW-CT-9V DC Power Adapter - Minimize Need to ...
Rating: 4.3 · ‎15 reviews
If you need to turn around your charger at one position so that the laptop will charge, that means your dc jack is dead. Otherwise your laptop ac adapter should be replaced.
If you need to purchase a new toshiba charger, you may click the following link to take a look at Toshiba Satellite M30 AC Adapter:
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Dell portables use a sensing wire in the barrel of the adapter plug to determine the wattage of the ac adapter. If that fine wire in the center of the plug is bent or broken, the system cannot ID the adapter and the battery charger is disabled.
SO, first try a known good AC adapter for a D-Series Dell (You might be able to check with Geek Squad at a local Best Buy if you don'e have access to another ac adapter) If a known good ac adapter works, then replace the ac adapter.
If a known good AC adapter does the same thing then the fault is in the charging circuit of the motherboard and the motherboard will need to be replaced.
