Does the battery make good contact with the pins in the camera? Try putting a bit of pressure on it or move it etc to see if the unit comes to life, if it does even momentarily you have a loose connection at one of the pins. Since you have a second identical camera check the continuity reading between all the pins on the good camera and then the bad and compare the two should be exactly the same. If not there's an internal problem wit the unit.
You don't need the disc. Buy Corel's latest videostudio x2 for editing. To extract the video files from camera just plug into computer with USB cable and search the camera for files.
You CAN NOT use the Firewire to capture your footage like DV or HDV camcorders. I too Have a macbook pro and use FCPS2 to edit my footage. If you want to get the footage off of the HD7u, you'll have to connect via USB2.0 and download the .TOD files and use a program to convert them. I use MPEGStreamclip. It will work with the .TOD files and convert them to a format that iMovie or FInal Cut will understand. If this is not for professional work you'll probably be fine converting the footage to the HDV standard or DV standard and not have to render in FCP to edit the footage.
Caution... MPEG2 codec may be needed. If you have FCP or have Quicktime pro, you probably already have it other wise you can purchase it from apple for $29.99 or if you try real hard (not to hard) you can probably find it on a torrent for free.
I hope this helps your situation
Ciza
