Year 2002! Btu's are 5000 to 7000 & the other one is 8000 to 12000 btu, it depends on what size air cond. you have, below is two links one is owners manual, the other is installation manual, hope this helps!!!
http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201184505.pdf
http://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%201184505.pdf
SOURCE: Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
SOURCE: I need to know the BTU of our Whirlpool Air
Th info I keep finding is 14,7000 which is just over 1 ton of cooling. Each ton is 12,000 Btu. Probably designed to cool about 400-500 square feet.
SOURCE: maytag 5000 btu air conditioner, model #
I could not find that model number listed, but no matter. It sounds like your drain line is plugged with something and you need to clear the line. What has always worked best for me is a guitar string because it is flexible enough not to damage anything but rigid enough to work on cloggs.
SOURCE: I am looking to download
HERE'S THE ANSWER TO YOUR PROBLEM:
This is the solution for your problem. Just copy this link and paste it to your address bar and get the manual:http://dl.owneriq.net/4/476db133-875e-4dcb-bc04-7376e729b2aa.pdf.
Your problem is solved. Thanks....
SOURCE: My window is only 18-19" wide. I need to know the
You can find the information you're looking for, as well as the Owner's Manual and Installation Guide at the following link.
http://www.frigidaire.com/products/air-conditioners-dehumidifiers/window-air-conditioners/fra052xt7
Hope this helped you.
