20 Most Recent Whirlpool ACQ158XP Wall/Window Air Conditioner Questions & Answers
My GE air conditioner wont stay on .shuts off and on by itself
it may be thermostat cycling it off.
9/6/2015 9:42:06 AM • Whirlpool... • Answered on Sep 06, 2015
Aez05lqw1
remove from window, take outside and clean
9/6/2015 9:38:35 AM • Whirlpool... • Answered on Sep 06, 2015
Why is my window air conditioner not blowing hard
switch, dirty coil/filter
9/6/2015 9:34:48 AM • Whirlpool... • Answered on Sep 06, 2015
2answers
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
3/6/2015 5:35:08 PM • Whirlpool... • Answered on Mar 06, 2015
I have a Whirlpool Model ACQ158XPO wall/window air conditioner. Motor comes on but it does not cool. Any suggestions?
Its really tough to troubleshoot window units without pulling the cover off. If I was standing there looking at it without tools in my hand I would first make sure the fan/cool switch was in the fan high cool mode and that the thermostat was turned all the way to the coolest setting. Beyond that it needs to go in for repair. Wish I could be more help. Good luck.
10/14/2014 7:29:07 AM • Whirlpool... • Answered on Oct 14, 2014
My Whirlpool window air conditioner
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
7/17/2014 1:43:48 AM • Whirlpool... • Answered on Jul 17, 2014
2answers
Unit lights up and hums but does not blow air
mcdevito75 here, Sounds like the fan motor is haging up or needs to be replaced, try the switch on/off then on/off a few times see if the fan kicks on, if not see your local a/c repair shop, they come to the house.
7/6/2014 8:12:39 PM • Whirlpool... • Answered on Jul 06, 2014
WHERE CAN I FIND AN AIR FILTER FOR Whirlpool Air Conditioner Model ACQ062MM0
It depends where you are. This company has them http://www.repairclinic.com/Shop-For-Parts/a16b5d619658/Model-ACQ062MM0-Whirlpool-Air-Conditioner-Parts?z=100
3/11/2014 6:34:41 AM • Whirlpool... • Answered on Mar 11, 2014
Reset thermostat winter
It's an earth wire need to be connected to solid body .
1/5/2014 11:03:47 PM • Whirlpool... • Answered on Jan 05, 2014
Power no air
PC board.
12/7/2013 2:18:05 PM • Whirlpool... • Answered on Dec 07, 2013
Can the styrofoam insulation in our air conditioner be replaced or patched?
Yes it can but you will have to use expandable foam. You must shape it after it drys. Old trick, works like a charm. Should be an under $5 repair
12/7/2013 2:17:44 PM • Whirlpool... • Answered on Dec 07, 2013
Very little air flow
Dirty coil or frozen or failing blower motor.
12/7/2013 2:03:38 PM • Whirlpool... • Answered on Dec 07, 2013
Acq158xr1
That is typically a tale tale sign of ice. Thaw the unit by circulating the fan for a few hours. That's the easiest and cheapest repair.
12/7/2013 1:51:16 PM • Whirlpool... • Answered on Dec 07, 2013
My home AC is not working my compressor come on
1st check breaker box to see if you have power (tripped breaker) If you have power you should have a licensed contractor diagnose it. Caution the voltages in testing can be high, even deadly if you don't know what you are doing. You must have the proper tools to test. 3rd check 24v signal power. 4th test the capacitor to see if it is within 5% of rating 5th is there a start kit/compressor saver/5-2-1/start assist, or does it need one. 6th test windings and add up the resistance.
12/7/2013 1:42:34 PM • Whirlpool... • Answered on Dec 07, 2013
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
77 questions posted
Top Whirlpool Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Heating & Cooling
Most Popular Question
get inside c unit looks like slide out
  • Heating & Cooling
