Lights do not work on panel - dishwasher not working
SOURCE: GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
SOURCE: I need a wiring diagram for my Jenn-air dishwasher
I removed the circuit board and reinstalled it.
Now is works fine. Bad connection, I guess.
SOURCE: Jenn Air Dishwasher Model JDB1100AWS Light Normal/Extra Rinse are the only two buttons that work.
have you solved youre problem ? i have a dead 11000 series unit no one has any input so much for trying to save a buck.time to switch to paper plates i had a bosh before this i went through 3 contol boards then threw it out i miss the old manual controls
SOURCE: Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
SOURCE: jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
