How do we correct the error code
SOURCE: Samsung washing machine J1453. Error
Had a same fault code and also sometimes had the reverse kept filling - soultion was that the small flexible pipe up to the pressure sensor had a crack (fatigue mahine was only 1.5 years old) in it next to the sensor - found it by sucking and blowing down the pipe while it was not connected to the sensor (with the electric off ) - Replacment pipe can be found at any good local washing machine parts shop/store
SOURCE: Samsung Washing machine fault
Had the same problem - I posted full description in another 4E post - But my problem was a crack.split in the pipe to the sensor
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
SOURCE: why 4E error code keep appearing on my Samsung washing machine
The 4E error indicates that the washer hasn't detected enough water coming into the unit. The problem could be in your incoming water line (low water pressure), the washer hoses, the inlet valves, or the sensors that detect the length of time to reach a specific amount of water in the washer. It can even be caused by having the outlet hose positioned too low in the discharge pipe or sink.
First check the obvious possibilities: make sure that the shut-off valves have been opened. If you hear water running into the washer and then into the discharge plumbing after a few minutes, raise the end of the discharge hose to a level above the washer fill level.
Shut-off the incoming water and remove the washer fill hoses. Place a bucket under the hoses and open the shut-off valves. Check that you have good water pressure; the washer is looking for the tub to fill in about 8 minutes. Then turn off the water. Clean the filters in the hose at the shut-off valves and the ones inside the washer at the inlet valve. You may want to replace the washer fill hoses; some anti-flood hoses will constrict if they detect a leak and limit the water pressure.
If the water flow at the hoses is good and isn't exiting the washer, then the problem is either the inlet valve or the water flow sensor. Does any water reach the tub? If it doesn't, check the inlet valve and make sure that it is getting the proper electrical signal from the control unit. If water is reaching the tub, then the problem in the flow sensing system. Some washers use an air tube that helps check the pressure in the system. If this tube is leaking or clogged, the sensor will give incorrect messages. Other systems have a small switch that moves as the water passes through the inlet valve. This can fail.
There can be other problems that give the same symptoms. If you post the model number of your washer, I may be able to point you to the correct diagnostic steps.
