Hi Anonymous, The links below are youtube video's, I hope this helps....CHEERS..
1st shows a craftsman mower with problems....
Craftsman Lawn Tractor stalling out
2nd shows a craftsman seat safety switch disabled....
Seat Safety Craftsman Disablement
3rd shows all safety switches disabled....
Disable all lawnmower safety switches
4thHow to test lawn mower electrical safety switches....
5th How to test a solenoid....
How to test lawn mower solenoid
6th How to test a lawn mower Key switch....
How to test lawn mower key switch
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
SOURCE: my mtd pinto mower engine cuts out when cutters engage - why?
it sounds as if your carb is dirty remove bowl on carb i"ll bet it's it's dirty if so you will need to remove the carb and clean it
SOURCE: when mower gets hot it cuts off crank back up run a min cut off
1 of 2 things happening
first change the fuel filter seams that the gas is vapourizing
If that does not fix it replace the engine coil as it heats up it is breaking down in voltage causing the engine to die
SOURCE: ride on Mountfield Lawn mower 1228H - engine cuts out
Check to make sure there is no obstruction in the blades or on top of the deck where the belt goes. Also check that your pulleys turn freely and that a bearing didn't freeze up.
Let me know if this helps.
roundo4
