Green LED flashes at turn on but after a minuet the TV comes on
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
SOURCE: constant green blinking light Mitsubishi tv WS-65513
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
SOURCE: flashing green light
I had the same problem due to power surge.Repairman came and said power board replacement might fix--$300 parts and labor, but if DM module is damaged, another $600-700. My set is 5 yrs. old. I'm shopping for a new LCD.
