20 Most Recent Mitsubishi WS-55613 55" Rear Projection HDTV Questions & Answers
my 55613 tv wont turn on just blinking green light
Mitsubishi... | Answered on Jan 26, 2019
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Mitsubishi... | Answered on Aug 30, 2017
you do have a bad power supply
Mitsubishi... | Answered on Jun 02, 2016
A hint--if the green power light comes on for a few moments and goes off do the self check this set has.
On the front of the set press and hold BOTH THE MENU AND INPUT (OR DEVICE) BUTTONS BOTH FOR AT LEAST 5 SECONDS. Release both buttons and look at the power button.
If this is the case the power light will blink a two digit error code--most common in this case is 2 blinks, a pause and 2 blinks--it will repeat the code up to ten times.
Let me know if you find an error code or the power light just blinks and never stops.
If this helped you rate this solution as I do this here for free.
SD TECH
Mitsubishi... | Answered on Dec 07, 2014
This model TV is a CRT projection and does not have a lamp. It has 3 CRT tubes (Red, Green and Blue). Unfortunately, you may need to have a trained TV technician diagnose this further.
Mitsubishi... | Answered on Nov 04, 2013
Light flashes two times, then pauses, then two times. Help!
Mitsubishi... | Answered on Oct 30, 2013
replace the hold its worn out
Mitsubishi... | Answered on Jul 19, 2013
1080 is a High Definition setting. If your Television is HD capabilities you need to make sure that the programming that you are viewing is being broadcasted in 1080. If it is not then you will see a difference in picture quality and sound. If no color at all and program being watch is HD programming check your connections on back of Television. depending on what kind of input the Television is receiving you might need to try new cables or a new input. Good luck
Mitsubishi... | Answered on Dec 19, 2012
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
176 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
replaced 4 capacitors dm board
  • Televison & Video
