you can try out some guide from reliable-store
they also provide live chat feature for instant help and it's very useful
using that I fixed my own excavator
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode
Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode
Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode
City Mode
Mute Button Press and release
To Turn Auto Mute Off
X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Yours appears to be an older model, but should have similar functions to the current generation. Heres the manual for a similar unit. If it helps, please remember to rate my solution.
To the original poster, the officer could have used laser, vascar, or pacing to issue a speeding ticket. The officer also could have used a very quick burst of instant-on radar which Cobra brand radar detectors are notorious for not detecting. The officer also could have used a 35.5 Ka band radar gun. Cobra and other import brands of radar detectors usually have great difficulty detecting 35.5 Ka band radar.
X stands for wide band radars(easy to detect,lots of false alarms) K/Ka stands for pulse band radars(similar signal has auto doors) W,L stands for laser detection (very little false signals) Ku stands for signal most used on speed cameras V stands for radar detectors detector Have in mind that you can only lower your speed 20-30 km/h in city zones, and up to 50 km/h on highway.This depends on car,brakes and You.
Detecting of radar or lidar emissions depends on mounting of detector.In My experience it is best to mount it just above windscreen wipers.You must check if your detector is visible from license plate level. This is important for laser detection. For other measuring devices it's only important to be visible.Higher mounting facing downwards will reduce false X and K/Ka signals.It will reduce detecing of true as well, so it is all up to you.You must know that laser detecting only covers your car.It d'ont matter if a cop is 300m or 1800m away.X band has a large emission, and it is easily detected.K/Ka band is a pulse emitting and has a lot narrow detecting point.It is effective at max 800m.In ether case speed can be reduced 20-30 km/h in city, and 30-50 km/h on highway.
Assuming the model number is COBRA XRS 9500CS 11-BAND RADAR/360* LASER DETECTOR WITH DIGVIEW DATA DISPLAY & VOICE ALERT This is what we can find out about it.
DETECTS 5 RADAR SIGNALS: XBAND, KBAND, KA SUPERWIDE, VG-2 RADAR DETECTOR-DETECTOR, SPECTRE 1 RADAR DETECTOR-DETECTOR
You should try to find out what type of radar devices your police uses.ESD7000 model does not support some devices such as Ku band radar signal, but it should detect all laser signal.Laser signal is often jammed by sun light.If your police uses radar detector detectors VG2 it will force your detector to hide from it making it invisible for detecting.Try talking to someone who has other type of detector that works in your town.It is possible that you will be forced to buy another model.
