Drills Logo
Kevin still Posted on Jan 31, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Lincoln 14.4-18v charger that showing a hot-cold pack delay. I have two batteries that haven't been used in a few days and the code comes up on both.
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,001 Answers
  • Posted on Dec 16, 2016
wwlvictoria
Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603956
Points
6027
  • USB quick charge 2.0 charger,you can get 75% power from empty in 30 minutes. It also charges your non-QC2.0 devices at up to 2.4 amps.ideal for travel use.
Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
L Pfaff
Level 3:
Top Expert:
  • Master 11,573 Answers
  • Posted on Jan 31, 2016
L Pfaff
Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587876
Points
181713
Insert batteries in and out of charger quickly several times to help make better contact, its worked for me in the past. seems like contacts get dirty and this gets them shinning again.
1 Related Answer
Repair Ahjoshe
  • 885 Answers
  • Posted on Jan 30, 2012
SOURCE: my charger displayed cold/hot pack
This is indicating the battery is too hot to charge, usually after coming off the tool right after some hard work. During the charging process the battey heats up so if you charge a hot battery, thereby making it hotter, you shorten the lifespan of the battery considerably. If you are getting a hot/cold pack delay indication on the charger, it should automatically start charging once the battery has cooled down sufficently.
A makita battery charger is flashing red with a battery plugged in, what does this mean?
On the Makita 18-V DC18RA charger, the flashing red light means that the battery is not at the correct temperature for safe charging. If the battery is hot (from use or being in direct sunlight), charging will begin when the battery cools down. If the battery is cold, then charging will start when the battery warms up. (Note: the cold battery could have moisture condensation issues. This could delay the start of the charging cycle.) Home Depot has the manual for this charger here: https://images.homedepot-static.com/catalog/pdfimages/35/35393127-7c0b-4668-8609-9104ae7cc187.pdf . I suspect that Makita uses the same "code" on all of their chargers.
I hope this helps.
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Battery won't charge. Light pattern on the charger is " ._._._. Is this battery bad.
What is the residual voltage on your battery, if it is too low, charger will not engage. If the voltage is below the threshold allowed, simply jolt the Nickel Cadmium battery with a car charger to bring it up, then install on charger.
1helpful
My nikon coolpix camera battery dided and now when i plug it in to the charger it wont charge. is there some sort of reset i can do?
If you haven't use your Nikon Coolpix camera battery for a long time and now there is no power, when you first plug it to charger it maybe show none action. And charger longer it will be well. But if your battery Nikon camera battery are used well these days, and it won't be charge. It means you need a new Nikon battery charger
Apr 29, 2011 • Cameras
7helpful
2answers
My charger displayed cold/hot pack delay during charging
3helpful
DeWalt 18v batteries charge light flashes quickly why?
Here are the codes for Dewalt Charger Flash indications:
---- ---- ---- ---- ---- ---- ---- Charging
------------------------------------ Charged
----- - ----- - ----- - ----- - ----- Hot/Cold Pack delay
- - - - - - - - - - - - - - - - - - - Replace pack
Feb 07, 2011 • Garden
HELLO: OUR MILWAUKEE 48-59-2401 BATTERY CHARGER IS NOT CHARGING OUR 48-11-2401 BATTERY PACKS. WHEN YOU RUN THE PACK DOWN TO 1 OR 2 LIGHTS & PUT IT IN THE CHARGER BOTH RED & GREEN LIGHTS FLASH....
If both lights are flashing after you put a cool battery on the charger, the battery is bad. It could have a bad, worn or shorted cell or other problems inside and the charge will not charge it as long as it reads it as a bad battery. Rechargable batteries do have a finite life determined mainly by how many times you recharge them.
Jan 20, 2011 • Garden
Charging Batteries
This could happen if the batteries have been recently used, and are "hot". Chargers use one, or a combination of, "end of charge" detectors. Either it's timed, detects a slight drop in voltage, or senses temperature. Try waiting 30 minutes to an hour after use before charging. Also, be sure the ambient temperature is within parameters. Too hot or cold (we live up north...gets cold in the garage) will affect the charger.
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
