check chiltons manuals, they usually have wiring diagrams in the back of them to show you all you need. its hard to find online ones. you always have to pay for those ones
Check for un-isulated connection on the hot wire lead. It might have been after-market but on mine the connection would short out, blowing a fuse. 1 inch of heat shrink tube fixed the problem.
I tow my 2005 Jeep Wrangler behind my motor home. I installed a Jeep trailer towing wiring kit to the rear lights. the bought a long trailer wiring kit and ran it from the front of the Jeep to the Jeep tralier wire plug. Pluged it in and pluged the other end into the motor home trailer light recptacle. I used only four wires plus ground. There is probably a way you could tap into the wiring harnes under the hood but not having a wiring diagram this is the best I could come up with and all lights do work. You can buy a test plug with led lights that plugs in both male and female, real handy for checking connections.
If it has flanges on both ends, just unbolt it and replace. If it has welded pipes you will need to cut it off and use adapter sleeves and clamps. Really not rocket science...at worst, you may need to remove the hangars on the rear portion of the system to get enough room to install.
Did you go off road in the mud or woods?If so the connecting plug where all the connect probably has gotten disconnected.I think it is near or between the fuel tank and rear bumper.
