www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
Try these tips to fix the so-called "black screen of death".
Tip 1: The main reason of HDMI black screen problem due to HDMI
cable may be damaged and not properly connected to the PS3 console. Please
follow below step to troubleshoot PS3 HDMI cables problem:
1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back
in. If you found out that your HDMI cable is damaged, borrow a
friends cable and try it. If your friends cable works fine, and the
black screen error disappears. Then you can buy a brand new HDMI cable
for a replacement.
Tip 2:Only try as last resort. There is a possibility you'll lose all data on your PS3'shard drive. If tip 1 didn't work, you will need to go a step deeper and reset your console. Most PS3 gamers are not aware that Sony
actually included a black screen of death troubleshooting method and
other HDMI problems in the PS3 manual, you can find it under
the troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset
back your PS3 to its default HDMI settings without impacting your gamer
profile, and other storage data on the hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed by two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
The main reason of HDMI black screen problem due to HDMI cable may
damage and not proper connected to the PS3 console. Please follow below
step to troubleshoot PS3 HDMI cables problem:1) Restart your
PlayStation 3.
back in.
If you found out that your HDMI cable is damage, do borrow your friend
cable and have a try. If your friend cable work fine, and the black
screen error disappear. Then you can buy a brand new HDMI cable for
replacement. Tips 2: If tips 1 not working,
you need to go another step deeper by reset your console. Most of the
PS3 gamers not aware that Sony actually done include in the black screen
troubleshooting method and other HDMI problems in the PS3 manual, you
can find it under troubleshooting section - topic "console reset". If
you do it correctly, the console reset fix will allow you to reset back
impacting your gamer profile, and other storage data in hard drive. You
following steps:
3. Listen for one long beep, followed to two shorter beeps.
I think maybe the following steps might help you out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Make sure the HDMI cable is connected to the HDMI OUT port on the
back of the PLAYSTATION 3 system. Connect the other end of the HDMI
cable into the HDMI Input port of the TV or display monitor.
While the PLAYSTATION 3 system is in standby mode (red light on the
front of the system), hold down the
touch-sensitive power button on the front of the system until the system
goes into standby mode again . (So the light cycle would go from:
red light --> green light --> then back to red light). This
will ensure that you have held down the power button long enough to
reset the Video Output Settings.
Turn on the PLAYSTATION 3 system and once the system finishes powering
up, the Video Output Settings will automatically reset to the standard
resolution (or detect the current display output settings of your
TV/monitor).
Are you sure it's the TV and not the video source ? Have you tried other video sources ? You can also try to switch over to component cable. The red/green/blue colored cable. You only need HDMI for blu-ray to get the 1080p. If your TV is only 1080i then you don't even need to use HDMI. Also, some sources actually look better with a component cable compared to HDMI. Give it shot.
