Please read all the info before you start and if you have any question please feel free to message me at
[email protected] or just give me a call @ Cell #
1-503-432-9904 Ask for Dave!
What you'll need to do is remove the stand and the back cover. Once you have both the back cover and stand off you'll need to put the stand back on the TV so that you will be able to set the TV up right! Then you will need to locate the Y sustain board. The Y sustain board is the board that is to the left side of the TV if you are looking at the TV from the back side. The Y sustain will have a large heat sink on it 3 1/4 inch's wide and 6 inch's long. There is a small heat sink 3/4's of an inch wide and 3 1/2 inch's long just above the large heat sink. A little to the right of the larger heat sink. The little heat sink also has two large
capacitors just to the left of it. Once you have located the small heat sink you will want to look just to the right of it and you'll see two Blue with Yellow centers
adjusters.
You do not want to touch any of the
adjusters other then the two that has the
location #'s VR1 & VR2 next to them. Please make sure you have located the right
adjusters by making sure that the location # next to them is VR1 & VR2. Start with adjuster VR1. Before you make any ajustments take a felt tip pen and make a stright
thin line over the top of the Blue with yellow center
adjusters. This will help you put the
adjuster back in to the factory setting position if you need to start over and it will also give you an ideal as to how much you have
adjusted the
adjuster. At this point you should have the TV with the back cover off and the TV in the up right
position with the stand on the TV. Now you will need to find a friend to
watch the screen while you make the
adjustment to Location # VR1 & VR2. plug in the TV and turn it on. The TV should be cold, another words if you have had the TV on at all let the TV cool down for about an hour or so before you do the
adjustment. Start the
adjustment by turning VR1 counter clock wise slowly untill the specs on you screen go way. If the specs on you screen get worse then put the
adjuster back in the factory set position and
turn the
adjuster VR1 clock wise
until the specs go away or lessen. In some cases you will not be able to get ride of all the specs but you will be able to lessen the amount of Green or Red specs on the screen. If adjusting VR1 dose not completely clear all the Red or Green pixels from your screen make the same adjustments to VR2!
WARNING: Plasma televisions use high voltages to display images on the screen. Be sure to unplug your unit, and then press the power button on the front panel to discharge the capacitors in the unit before beginning to open up the case. Always observe the necessary precautions when working around electrical equipment and never touch anything with your bare hands that may be carrying a stray voltage. By following these instructions you agree to assume all risks involved with the repair of your unit, and agree to hold me harmless of any damages that may result to either you or your television from the following of the instructions on this page.
Please feel to message me or give me a call if you have any question regarding the repair of your TV!
Thank you!
Dave
All TV Repair
Cell # 1-503-432-9904
[email protected]
