To erase the Toner symbol:-
Step 1:- Switch off the machine.
Step 2:- Press 0 and 8 buttons and switch on the machine
Step 3:- AD will appear on the display
Step 4:- Press 695 and then start button
A value either 1 or 0 will display
If it is 0 make it 1 and press interrupt button
If it is 1 make it 0 and press interrupt button
Switch off and on to check.
To erase the spanner symbol:-
Step 2:- Press 0 and 8 buttons and sitch on the machine
Step 4:- Press 251 and then start button
A value will appear on display
Press 0 now and then interrupt
Now AD appears on the display.
Press 252 and repeat the step 4
Press 253 and repeat the step 5
Switch off and on to sheck
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
SOURCE: Dear sir, when i start my Toshiba e.Studio 166
yes sir it is signal your copier exproser lamp or lamp fuse is cut please chack it then solve your problem
SOURCE: DRIVER TOSHIBA E STUDIO 166 PARA WINDOWS 7
www.toshiba.com.... support...downloads...drivers
SOURCE: toshiba e-studio 166. i am looking for Mac driver
http://www.eid.toshiba.co.nz/n_driver_es207.asp
OK link above.
SOURCE: error F14 in my Toshiba e-studio 166
how to reset error code f14 in the toshiba e-studio 160
