You also must subscribe, with your local phone company and have caller ID, it is a feature and they do charge a monthly fee for it. If you do have that feature and are still having trouble,
1. Code *3370#-Activate Enhanced Full Rate Codec (EFR) - Your Phone uses the best sound quality but talk time is reduced my approx 5%. #3370# -Deactivate Enhanced Full Rate Codec (EFR). 2. *#4720# -Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time. *#4720# -Deactivate Half Rate Codec. 3. *#0000# -Displays your Phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type. 4. *#9999# -Phones software version if *#0000# does not work. 5. *#06# -For checking the International Mobile Equipment Identity (IMEI Number) 6. #pw+1234567890+1# -Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols). 7. #pw+1234567890+2# -Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols). 8. #pw+1234567890+3# -Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) 9. #pw+1234567890+4# -SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols). 10. *#147# -(vodafone) this lets you know who called you last. 11. *#1471# -Last call (Only vodofone). 12. *#21# -Allows you to check the number that "All Calls" are diverted to. 13. *#2640# -Displays security code in use 14. *#30# -Lets you see the private number. 15. *#43# -Allows you to check the "Call Waiting" status of your phone. 16. *#61# -Allows you to check the number that "On No Reply" calls are diverted to. 17. *#62# -Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to. 18. *#67# -Allows you to check the number that "On Busy Calls" are diverted to. 19. *#67705646# -Removes operator logo on 3310 & 3330 20. *#73# -Reset phone timers and game scores. 21. *#746025625# -Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible. 22. *#7760# -Manufactures code. 23. *#7780# -Restore factory settings. 24. *#8110# -Software version for the nokia 8110. 25. *#92702689# -Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again. 26. *#94870345123456789# -Deactivate the PWM-Mem. 27. **21*number# -Turn on "All Calls" diverting to the phone number entered. 28. **61*number# -Turn on "No Reply" diverting to the phone number entered. 29. **67*number# -Turn on "On Busy" diverting to the phone number entered. 30. 12345 This is the default security phone lock code. 31. press and hold # -Lets you switch between lines.
Nokia Mobile Phones Security/Secret/Unlockcodes. The Codes shown below may not work for some models but these codes would work with almost all nokia mobile phones. These codes might not work on some of the newly released models. It's good for us to keep these codes handy. I have tried with several models but I couldn't try on all the models since I don't have all the handsets with me. I am still doing research with all the nokia mobiles so that we can use the codes better when we actually need them without using software or any kind of hardware to reset or unlock or to ask around here and there. Well let?s start with the default security code. 12345 is the default security code for all the nokia mobiles. To use this code, we need to go to the settings and select the appropriate security where you want to apply. Generally we use this code to reset the phone settings to default (Restore Settings). Let me type down the codes and their respective descriptions:
*3370# is to activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but battery talk time is reduced my approximately 5%.
#3370# is to activate Enhanced Full Rate Codec (EFR).
*4720# is to activate Half Rate Codec (HRC) - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
*4720# is to deactivate the Half Rate Codec.
*#0000# or *#9999# displays your phones software version, Software Release Date and Compression Type.
*#06# to see the IMEI number (International Mobile Equipment Identity) [This number is unique for all handsets]
#pw+1234567890+1# displays Service Provider Lock Status. (press "*" button multiple times to obtain the "p? , ?w" and "+" symbols).
#pw+1234567890+2# displays Network Lock Status.
#pw+1234567890+3# displays Country Lock Status.
#pw+1234567890+4# displays SIM Card Lock Status.
*#147# or *#1471# displays the last received call (only with selected Service Provider).
*#21# displays the recent diverted calls.
*#2640# displays the security code which is being used.
*#30# displays the private number.
*#43# displays the call waiting status.
*#61# displays the number which "On No Reply" calls are diverted to.
*#62# displays the number which "Divert If Unreachable" calls are diverted to.
*#67# displays the number which "On Busy Calls" calls are diverted to.
*#67705646# removes operator logo on particular models.
*#73# resets every phone timers and game scores.
*#746025625# displays the SIM Clock status, if your phone supports the ?Power saving feature? "SIM Clock Stop Allowed", you will get the best standby possible time.
*#7760# displays manufactures code.
*#7780# restore factory settings. (you?ll loss all your contacts and sms saved on our phone by doing this).
*#7370# or *#7730# will format the phone memory. You'll need to enter the security code.. i.e. 12345.
*#92702689# displays: Serial Number, Date Made, Purchase Date, Date of last repair (0000 for no repairs), Transfers User Data. You can?t exit this mode without turning offthe phone.
*#94870345123456789# clears the PWM-Mem. (Flash memory)
**21*your desired number# turns on "All Calls" to be diverted to the phone number entered.
**61*your desired number # turns on "No Reply" to be diverted to the phone number entered.
**67*your desired number# turns on "On Busy" to be diverted to the phone number entered.
Some of these codes may work on some models and some may not.
If anyone could add more codes, please add them as your comment so that we can work better and help each other. Thanks.
here are codes for nokia fones that you guyz may need a lot
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
*#4720# Deactivate Half Rate Codec
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
*#9999# Phones software version if *#0000# does not work
*#06# For checking the International Mobile Equipment Identity (IMEI Number)
#pw+1234567890+1# Provider Lock Status. (use the \"*\" button to obtain the \"p,w\" and \"+\" symbols)
#pw+1234567890+2# Network Lock Status. (use the \"*\" button to obtain the \"p,w\" and \"+\" symbols)
#pw+1234567890+3# Country Lock Status. (use the \"*\" button to obtain the \"p,w\" and \"+\" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the \"*\" button to obtain the \"p,w\" and \"+\" symbols)
*#147# (vodafone) this lets you know who called you last
*#1471# Last call (Only vodofone)
*#21# Allows you to check the number that \"All Calls\" are diverted to
*#2640# Displays security code in use
*#30# Lets you see the private number
*#43# Allows you to check the \"Call Waiting\" status of your phone.
*#61# Allows you to check the number that \"On No Reply\" calls are diverted to
*#62# Allows you to check the number that \"Divert If Unreachable (no service)\" calls are diverted to
*#67# Allows you to check the number that \"On Busy Calls\" are diverted to
*#67705646# Removes operator logo on 3310 & 3330
*#73# Reset phone timers and game scores
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature \"SIM Clock Stop Allowed\", it means you will get the best standby time possible
*#7760# Manufactures code
*#7780# Restore factory settings
*#8110# Software version for the nokia 8110
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
*#94870345123456789# Deactivate the PWM-Mem
**21*number# Turn on \"All Calls\" diverting to the phone number entered
**61*number# Turn on \"No Reply\" diverting to the phone number entered
**67*number# Turn on \"On Busy\" diverting to the phone number entered 12345 This is the default security code press and hold # Lets you switch between lines
*#3283# or *#DATE# Date of Manufacture via:
*#682371158412125# Software Version
*#92702689# - Enter the service menu
*#7370925538# - Delete all the content of the wallet and the wallet code
*3370# This Nokia code
activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best
more Talk Time
*#4720# With this Nokia code
you can deactivate the Half Rate Codec
symbols)
symbols)
*#147# This lets you know who
called you last (Only vodofone)
vodofone)
*#21# This phone code allows
*#2640# Displays phone
number
"Call Waiting" status of your cell phone.
to
*#67705646# Phone code that
removes operator logo on 3310 & 3330
game scores
code
settings
the nokia 8110
**21*number# Turn on "All
**61*number# Turn on "No
**67*number# Turn on "On Busy"
*3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your
Nokia cell phone uses the best sound quality but talk time is reduced
my approx. 5%
*#4720# With this Nokia code you can deactivate the Half Rate Codec
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
*#147# This lets you know who called you last (Only vodofone)
*#21# This phone code allows you to check the number that "All Calls" are diverted to
*#2640# Displays phone security code in use
*#43# Allows you to check the "Call Waiting" status of your cell phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
*#67# Allows you to check the number that "On Busy Calls" are diverted to
*#67705646# Phone code that removes operator logo on 3310 & 3330
**21*number# Turn on "All Calls" diverting to the phone number entered
**61*number# Turn on "No Reply" diverting to the phone number entered
**67*number# Turn on "On Busy" diverting to the phone number entered
Just call the number that the unit is connected to from another phone, cell phone for example. The unit will get the date and time of the call and it will be set on the display.
Nokia CODES DESCRIPTIONS *3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5% #3370# Deactivate Enhanced Full Rate Codec (EFR) *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time *#4720# Deactivate Half Rate Codec *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type *#9999# Phones software version if *#0000# does not work *#06# For checking the International Mobile Equipment Identity (IMEI Number) #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols) *#147# (vodafone) this lets you know who called you last *#1471# Last call (Only vodofone) *#21# Allows you to check the number that "All Calls" are diverted to *#2640# Displays security code in use *#30# Lets you see the private number *#43# Allows you to check the "Call Waiting" status of your phone. *#61# Allows you to check the number that "On No Reply" calls are diverted to *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to *#67# Allows you to check the number that "On Busy Calls" are diverted to *#67705646# Removes operator logo on 3310 & 3330 *#73# Reset phone timers and game scores *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible *#7760# Manufactures code *#7780# Restore factory settings *#8110# Software version for the nokia 8110 *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again *#94870345123456789# Deactivate the PWM-Mem **21*number# Turn on "All Calls" diverting to the phone number entered **61*number# Turn on "No Reply" diverting to the phone number entered **67*number# Turn on "On Busy" diverting to the phone number entered 12345 This is the default security code press and hold # Lets you switch between lines *#3283# or *#DATE# Date of Manufacture *#682371158412125# Software Version
BTW, the batter is new.
