Vacuums Logo
Mitchell James Kaplan Posted on Dec 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i replace the switch? - Kirby Heritage II Vacuum
Ian Griffiths
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 76 Answers
  • Posted on Aug 24, 2017
Ian Griffiths
Expert
Level 2:
New Friend:
Cheetah:
Answers
76
Questions
0
Helped
40443
Points
107
Need more info ie which model
2answers
Motor does not shut off
You can change the switch.
Jan 16, 2016 • Vacuums
How do i fix the brushbar on my vacuum cleaner there are three switches - power switch , brushbar switch ,and reset switch ,the latter does'nt seem to click ,should i replace this one
make sure you're getting power to the brush bar switch. If so there is a micro switch that activates the brush bar when you pull the handle back into the vacuuming position. Make sure that micro switch (in the ball assembly) is getting power from the brush bar switch.
Can you replace dyson on/off switch dc05 turbobrush
There are a number of places that list replacement switches. There are also a number of DC05 models, though the power switch is not likely to vary across them. Amazon, for instance, has a Dyson Switch for models including the DC05 and six other models (see here
Dyson Switch Dc03 Dc04 Dc05 Dc07 Dc08 Dc11 Dc14 On Off )
This video (ostensibly for a DC08, but the procedure should be pretty much identical) shows how to take the unit apart, get at and test the on/off switch, and replace it if need-be.
How To Change Dyson DC08 Switch An Easy To Follow Tutorial
Good Luck!
Switch bad need to bypass switch
Monica, I highly recommend you replace the switch. By passing the safety of a switch on any appliance or tool endangers both yourself and those around you. Just to by pass the switch, you would need to disassemble the appliance. If you are going to do this then get a replacement part and replace it. :) Safety comes first , especially where mechanical and electrical devices are used.
3helpful
4answers
Eureka Boss 4D (5892BVZ) - Switch Replacement & Fried Wires
If you got the handle apart, Id say you can probably fix it yourself. You might be able to patch it but I would say to maximize your effortrs please visit RepairClinic.com to find the exact replacement parts you need. They also have expert advice and guidance available.
I hope this works for you.
a
Oct 02, 2009 • Vacuums
The switch on our Hoover Windtunnel vacuum cleaner is not working. I have located the replacement part on your website...part#Ho-28161067, I've removed the wires from the switch. Is there any trick to...
no, follow the directions to replacing the switch and you should be good. if you got the kit then splice the wires and replace them with the wires profied and the wire nuts, you should be good.
Jul 20, 2009 • Vacuums
1helpful
2answers
Dyson Absolute won't stay on unless I am holding down the on switch. As soon as I release it, it shuts off.
You need to replace the power switch. Call the Dyson Helpline - they'll let you know where the closest authorized repair dealer is in your area. The repair dealer will inspect the power switch and replace it for you.
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
