Got to motherboard but can't get it out. any suggestions? and does the whole search engine have to come out?
SOURCE: problems with mitsubishi WD 65737
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
SOURCE: I have a WD-65737 Mitsubishi DLP TV . Last night
iI just had the sMe isuue. your tv needs a system upgrade. Contact Mitaubishi and they will email the upgrade link. You will need Aa thumb dri.ve upto 4gigs to downlaod...ensure its empty. They directions will guide u. thru.
SOURCE: mitsubishi WD-65737 DLP TV. TV powers on, green
I had exactly the same thing happen..I contacted Mitsubishi and they said the software needs to be updated..they are going to send me the link to download the software.
SOURCE: White spots on screen Need DMD
This is something of an urban myth....The "DMD chip" is actually the LCD display IC for the set; yes I have seen some listed on EBAY---still a myth----they are replaced (when a light engine is rebuilt in a space age lab or environment) under exacting conditions----if positioned a micron off in any direction picture will be tilted in some way---this is also not like changing spark plugs in a car, if you have a optical engine issue like spots etc, either get a rebuilt engine from Mitsubishi or buy a new set.
They usually require some parts for old engine (mounting brackets etc) be installed on new or rebuilt engine.
I did see the "chip" for another model listed on ebay today.(100.00 PLUS)
I understand the engine is expensive, I replaced a lot of them when the sets were in warranty---more Mitsubishi than any other brand with Samsung a distant second.
I am sure Mitsubishi does not offer the part for sale--they want to sell a tested rebuilt engine only.
I wish you luck but have little hope you will find a "part" other than the whole engine.
SD TECH
We changed the DLP chip but now my tv has a horizontal blue line about 2 1/4 in thick at the bottom of my tv. The blue strip also has white vertical lines in it. My tv is a Mitsubishi WD-65737 bought in 2009. Please help me.
