20 Most Recent Mitsubishi WD-65732 65" Projection HDTV Questions & Answers
2answers
Can the thermal sensor be replaced by the tv owner
Yes, it is located on the back of the lamp housing, you take the screws out of the fan duct and move it out of the way then there is a screw at the bottom of the thermal fuse on the back of the lamp housing unscrew it and pull the thermal fuse up and it will come out install a new one then put it all back together.
8/12/2021 11:22:23 PM • Mitsubishi... • Answered on Aug 12, 2021
2answers
TV start up green light comes on but blinks and then turns off.
You have a bad ballust
12/17/2016 5:14:09 AM • Mitsubishi... • Answered on Dec 17, 2016
I have a 65 inch Mitsubishi and I have Vertical white lines ALL the way across my screen in ALL inputs and above my menu.
it would be worth taking it in for a proper diagnosis and quote then making a decision on that information
8/9/2016 9:49:33 PM • Mitsubishi... • Answered on Aug 09, 2016
When I turn on TV picture color is green. How can I correct picture color?
check your input cables to be sure they are good & installed all the way, it that doesn't fix it you may need circuit board DM PWB part# 934C225002 see this site for availability & price: http://www.shopjimmy.com/catalogsearch/result/?q=934c225002 OR this site: https://www.encompassparts.com/item/7065536/Mitsubishi/934C225002/Pwb-dm_%28V33%29_G $468.40 includes core price of $150.00
1/3/2015 8:45:00 AM • Mitsubishi... • Answered on Jan 03, 2015
0answers
Red light
Be the first to answer 5/24/2014 3:54:30 AM • Mitsubishi... • Posted on May 24, 2014Be the first to answer
Flashing red status light
And a bulb is NOT firing. Try a new bulb..NOT a neoulx one though !!
5/8/2014 3:21:30 AM • Mitsubishi... • Answered on May 08, 2014
0answers
0answers
Mitsubishi dlp dark in the courner
To begin with remove lamp and make sure nothing happened there as if the light is partly obstructed it could cause thisYou can post a photo here or contact [email protected] and email them the photo to forward to me.SD TECHI worked on a lot of these sets when they were new but do not think I have seen or heard of a issue quite like this---too odd it happened shortly after a lamp was replaced.By the way I am sure you know or knew not to touch the face of the lamp with your fingers.
12/7/2012 8:19:41 PM • Mitsubishi... • Answered on Dec 07, 2012
3answers
How do you retieve the error codes?
All Mitsubishi DLP Televisions have a built in Diagnostic Decoder to store the last fault in memory. This will help the Mitsubishi Technician determine what area or part defect could exsist due to your television not coming on or turning off by itself. In order to read the error code from the front panel lights, you need to know how to access this information if it is available.
Please remember not to unplug the tv from the power outlet because this will reset the error code. The television must be in the power off state or shut off state to retreive the code.
Error Code Operational Check
Note: The TV must be in “Shut Down” and not have been switched Off, to perform the Error Code Operational
Check.
Pressing the front panel “ACTIVITY” and “CHANNEL DOWN v” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The “TIMER LED” flashes denoting a two digit Error Code, or indicating no
problem has occurred since the last usage.
Note: The front panel buttons must be used, NOT those on the Remote Control. • The number of flashes indicates the value of the MSD (tens digit) of the Error Code. • The flashing then pauses for approximately 1/2 second. • The LED then flashes indicating the value of the LSD (ones digit) of the Error Code. • The Error Code is repeated a total of 5 times.
Example: If the Error Code is “23”, the LED will flash two times, pause, and then flash three times, then this will repeat itself for four more times before the blinking stops. If you forget the code, you can start all over again after the LEDs have stopped blinking. Just remember you are looking for a two digit code, denoted by a pause in the middle.
Example: You are watching Television and after 20 seconds it shuts off with no picture or sound. By pressing on the front panel the INPUT and MENU at the same time starts the Diagnostic Procedure, and the TIMER LED will then blink six times, and then a small pause, then six more times. This is an error code of 66, and will indicate to the Technician a defect in the lamp ignition circuitry. This will help us to order parts for the repairs without guess work.
In addition to the above code retrieval procedure- most new Mitsubishi LCD & DLP televisions have a built in Error Code Log or menu system. To access this feature the television has to be on and have a picture or blue screen to read this fault menu . To read this Error Log in the television you have to use the Mitsubishi remote control and follow this procedure: Press & release the Menu button, followed by 3564 on the remote control. You will see Lamp time, Code & Status. If an error has happened, please read the numbers indicated under Code to our service person or office staff. We can determine by these codes how to handle service on your unit.
10/19/2012 7:32:14 PM • Mitsubishi... • Answered on Oct 19, 2012
Wd-65732 when it is turned on a minute or so it
May I know the status of the led light at the front panel to narrow down the caused of the symptoms.
7/29/2012 11:03:06 AM • Mitsubishi... • Answered on Jul 29, 2012
I have a sony weth no pic and no sound kdl40ex
Please confirm actual model number as one listed here is Mitsubishi and let me know which lights if any on front of set are doing anything.
3/12/2012 4:27:59 PM • Mitsubishi... • Answered on Mar 12, 2012
On power up tv shows
Power supply problem.Theres a leak parts in the power supply.For repair or replace power supply.
7/4/2011 4:34:10 AM • Mitsubishi... • Answered on Jul 04, 2011
Mitsubishi WD-65732 65" Projection HDTV Logo
71 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
wd 65737 screen comes mitsubishi logo
  • Televison & Video
