NEW STOVE GAS RANGE WORKS FINE JUST PLUGED IN AND ERROR F27 WILL NOT ALLOW OVER TO WORK
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Hey Jack, I am having the same issue with my gas range. Were you able to figure out what was wrong with your range? If so, what did you do to fix it?
