That sounds like the amp board died. Mackie parts can be hard to source, and Mackie is really slow to ship, so I suggest taking it to a Mackie authorized service center. Here's a link-
You might call mackie for a suggestion at 800-258-6883. Sometimes there may be older parts in stock at other Mackie distributers around the world. Here's a list of contact info Mackie International Distributors It doesn't hurt to ask and email is free!
I had good luck getting parts for various musical electronics out of Canada
Almost certainly the amp has failed, as per usual with these, you need to take it to the repair shop and see if it's worth fixing it then sell it once working or for spares if not. Sadly whilst Mackie make some really good kit their powered speakers are not amongst the most reliable
Have you checked fuses? You may have overloaded the amp and caused a fault internally. I have experienced power supply faults with Mackie products, but it may be a simple fix. Find a local repairer to have a look at it.
I would spend some time with contact cleaner, apply it to the switch contacts of any 1/4 inch jacks, and all of the connectors to the effects boards- it will entail some disassembly. Check all chassis ground connections you may have one that is a bit loose, broken, or corroded.
The Mackie support downloads for manuals has 2 sections- you needed to look at the top at the "discontinued products" Where these are.
This sounds like a ground loop. Make sure ALL (including the computer) interconnected devices are powered from the same receptacle. Make sure there are no lamp dimmers around as these can cause hum...
