Samsung N150 Notebook Logo
r
ram kumar Posted on Oct 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Voice is not going - Samsung N150 Notebook
David Payne
Level 3:
Top Expert:
  • Samsung Master 14,162 Answers
  • Posted on Oct 20, 2015
David Payne
Samsung Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998787
Points
455836
7helpful
2answers
I need to de-activate voice commands in my mobile Nokia-5233 pls guide me
go settings > Phone > Voice command > Tools > Voice command >Option
1helpful
How to bridge a dual voice coil subwoofer, the sub has 4 speaker wire connections coming out the back how do i bridge it two one
You have two choices of how to wire this sub.
First, is an 8 ohm load. This is called a series set up. Go from the positive of the amp to the positive of one voice coil. Then go from the negative of that voice coild to the positive of the other voice coil. Then go from the negative of that voice coil to the negative of the amp.
Second is a 2 ohm load. This is called a parrallel set up. Go from the positive of the amp to the positive of both voice coils. Then go from the negative of the amp to both negatives of both voice coils.
Make sure your amp can handle a 2 ohm load. If you have two subs, you will need a 2 channel amp.
3helpful
3answers
HOW CAN I GET THE VOICE PROMPTS TO WORK ON MY NUVI
Normally on front of screen there is promp for voice to mute or un mute, but if you don't see that go to settings and look for voice controls. But like I said is normally on screen right side area looks like a circle kind of.
I don"t have voice mail.
Pls fist put you sim in deffrent mobile and call to you number and you call is going to voice mail so going to voicemail so ok Thats you mobile problem but if you no going voice mail so active you voice mail device call to service proivedar of you network ...ok
1helpful
Can not get voice comands
if you mean like "turn right on Madison" as an example, you must have the tts voice selected ...that is the computer generated voices...it will not work with human voices....
go in the system setting and go to the voice option, and see if you have any TTS voices...if not, they may have been deleted..if so, go HERE and download the web updater and 1st see if there are any updates, then after that it will give you an option to add voices...just select one or some that are TTS...after there loaded to your gps, go back in the voice option and change it to one of the TTS voices.
if you mean you have no sound at all, post back and i will help you further.
bill
How do i make it speek the road names
you need to choose a computer voice instead of a human voice. go to change preference->voice...
in the voice selection menu, it will tell you this voice is computer male or human female, make sure you pick a computer one, then it will read the street name
1helpful
How do I use the my voice recording option on my pantech matrix
1. Go to Menu
2. Go to My Stuff
3. Go to Tools and Utilities
4. Scroll down to Voice Memo (8)
5. Click the center button and record
6. Push the center button again to stop
7. Push Back
8. Push back again
9. Go to Audio
10. Go to My Voice
11. Find your Voice Recording there.
13helpful
VOICENOTE TO PERSONALIZED RINGTONE ON BB CURVE 8330?? PLZ HELP!
Voice Notes to Ringtone.
If the voice note is stored on the device memory:
Go into the Media icon. Hit the BlackBerry® (menu) button and select ‘Explore’. Select ‘device memory/home/user/voice notes’. Highlight the voice note and hit the menu button. Select ‘Copy’. Hit ‘Up’ twice. Highlight the ringtones folder. Hit the menu button and click on ‘Copy Into’.
If the voice note is stored on the media card:
Go into the Media icon. Hit the BlackBerry® (menu) button and select ‘Explore’. Select ‘Media Card/BlackBerry®/voice notes’. Highlight the voice note and hit the menu button. Select ‘Copy’. Hit ‘Up’ twice. Highlight the ringtones folder. Hit the menu button and click on ‘Copy Into’.
Now the voice note will be available as a ringtone and can be assigned to a specific individual.
How do I use the voice command?
HI Con613,
Voice command is one of the feature of the mobile. It is important and if u understand it, it is very easy and useful to us.
Voice command is used to perform some sort of function (such as to open apps, camera, voice recorder, etc. and to call peoples) by giving voice command.
For it u need to go to voice command in tools in menu, then a list of apps appears. In it, u choose 1 apps, then it gives command to record voice. Record any voice of urs as command for it. When in standby mode or desktop, hold right soft key until voice command appears. Then give the same voice as recorded before to open the choosen apps.
Same process is to be applied for the apps.
For dialling people from voice command, u need to go to the person's contact. Go to options of it and add a voice as command for it. And same process is to be applied as to open the apps.
thank you
It is for mobile users.
If it is helpful for u, u can feedback me.
And i will help u later in other problems.
SAJAN
May 04, 2008 • GPS
1helpful
2answers
Voice recorder
the voice key is on the side of the display screen same side as pwr hold that moz-screenshot.jpgmoz-screenshot-1.jpgto record your voice let go when finished
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
