I would try a different card in the camera, and format it before using.....if that works then you may have to use some special software to retrieve the photos off the bad card if they are important to you....
The front head light adjustment on a vehicle can be rather complicated insofar as the vehicle needs to be a certain distance from a wall or screen, and the right and left beams need to be adjusted to specifications. I would recommend taking the vehicle in to a garage for such an adjustment short of having the correct specs for these adjustments. A repair manual for this vehicle may have the head light adjustment specs.
You should keep the oven unplugged until it is fixed or unless it is being tested.
I would first check to see if the oven is heating when it should not be.
You can place a cup of water in the oven, close the door, and let it set for about 30 seconds. (No longer or it may be damaged from overheating).
If it is, then I would suspect door switch trouble (see this text file) or an issue on the control circuit board, which we regularly repair with our $39.95 repair service.
It seems there isn't a software in your camera which can realize your video from your camera.
To download a player which can read the type of the files as your video.
For example, a file named: "file.txt" the ".txt"means the file type.
Hello, Normaly the repair service reset camera by using special file on the SD card.This file is impossible to find it on the internet.But you can try to update FW maybe it will help to this error message.You can try download lates FW for R727 from google.(Last FW version is
3.02.15). Then extract exe file and copy FW file to the SD card.Put
SD card into the camera and close battery door.Hold Shutter button and
power on camera.After FW update is complete just power off camera.Then try it again to swith on.If it will not help the only way is send camera into the repair service.
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Malcolm S
