Not necessarily--- the broken drive cable can be removed /replaced by removing the trimmer head from the shaft at the bottom
undo the clamp and if there is a small screw/ bolt into the shaft undo that as well and pull the head off
the flexible drive cable will slip out
check the ends and they should be square in form
Mostly the cable breaks but occasionally that square section will wear round
slip in a new cable and reassemble
