Serial number:CNF1034LT4 i core 3 ic:4104A-AR5B95H
Is BIOS setup availabe or not even that?
Does it "beep" at all?
There is a remote possibility that the problem could be your laptop screenr, so if you have another computer, you might connect an external monitor, enable it and see the result.
Else I'm afraid you've gor a serious problem with your motherboard.
Be it the laptop screen or the motherboard, problem probably exceeds the Do It Youlsels option and you should take it to a repair service.
i had just solved this problem yesterday, there
this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on
motherboard EPU
asp0800 near the CPU Socket
2.Press the IC with finger,at the
same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side
surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please
rechecked step 4
