Speed Queen AWS52NW Top Load Washer Logo
Manny R Posted on Aug 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer will agitate but will not spin. The lid switch does not appear to be the problem. Noticed the drive belt becomes slack. What may be the problem?
Bob L
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 413 Answers
  • Posted on Aug 05, 2015
Bob L
Expert
Level 2:
Mentor:
Answers
413
Questions
Helped
75793
Points
735
Make sure the pulleys are snug, and you say the lid switch looks good but did you ohm it out with your meter?
1helpful
Kenmore Top load washer 11022242510 Will not agitate or spin.
There could be several possible causes for your Kenmore top load washer not agitating or spinning. The actuator is one possibility, but it's not the only one. Here are some other potential causes to consider:
Lid switch: The lid switch is a safety feature that prevents the washer from agitating or spinning when the lid is open. If the switch is faulty, it may prevent the washer from agitating or spinning even when the lid is closed. You can test the switch by using a multimeter to check for continuity when the lid is closed.
Drive belt: The drive belt connects the motor to the transmission, which turns the agitator and drum. If the belt is broken or worn, the washer won't agitate or spin. Check the belt for signs of damage or wear, and replace it if necessary.
Motor coupler: The motor coupler connects the motor to the transmission. If the coupler is broken or worn, the washer won't agitate or spin. You can check the coupler by removing the motor and transmission and inspecting the coupler for damage.
Transmission: If the transmission is faulty, it may prevent the washer from agitating or spinning. This is a more serious issue that may require a professional repair.
Based on the symptoms you described, the issue could be with the actuator, but it's hard to say for sure without further testing. The actuator controls the shifting of the transmission from agitate to spin, so if it's not working properly, it could prevent the washer from agitating or spinning. You can test the actuator using a multimeter to check for continuity.
If you're not comfortable diagnosing or repairing your washer yourself, it's best to contact a professional appliance repair service to diagnose and fix the issue.
Flse72gcsa won't agitate or spin
There are a few potential causes for a Frigidaire FLSE72GCSA washing machine not agitating or spinning. Here are a few things you can try:
  1. Check the washer's load balance. If the load is unbalanced, it can cause the washer to stop agitating or spinning. Try redistributing the load evenly and see if that resolves the issue.
  2. Check the drive belt. The drive belt connects the motor to the agitator and the basket. If the drive belt is worn or damaged, it can cause the washer to stop agitating or spinning.
  3. Check the motor. If the motor is not functioning properly, it can cause the washer to stop agitating or spinning.
  4. Check the lid switch. The lid switch ensures that the washer lid is closed before allowing the washer to agitate or spin. If the switch is faulty, it can cause the washer to stop agitating or spinning.
If none of these troubleshooting steps resolves the issue, you may want to consider contacting a professional appliance repair service. They will be able to diagnose the problem more accurately and recommend a solution
Replaced lid switch, water level sensor and timer. Machine fills and does nothing - no agitate / spin
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
How to replace a bad lid switch to a washermachine
GE Prodigy Washer: Doesnt agitate or spin. Fills ...
Hello, If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Thanks
Washer wont agitate.
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
1helpful
2answers
Washer won't spin or agitate
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Machine wont agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Will not adjatate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
3helpful
My washer wont agitate ?
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Top Speed Queen Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
