My eton beamer3 gas scooter keep shredding my ctv belts I don't know zero about scooters help me please
SOURCE: my drive belt keeps shredding on my twist and go jinlun scooter
I'd say the pullies are misaligned, usually the back wheel axle shifts just enough to cause this.
SOURCE: Scooter has full charge but still won't go.
It probably means that the connections or wiring from your battery are loose or broken. When you add the extra current required to run the motors, the voltage is being lost. Monitor the battery voltage with a meter while trying to drive the scooter will prove this.
SOURCE: lost the main key and can't find the second key.
most keys for that type of scooter are the same, (not like a house or car key) call Pride 1-800-800-8586 for replacement or any Pride dealer can help you. Also, a paper clip can jump the ignition by placing it in their to get you around temp.
SOURCE: belt on scooter keeps breakin
Most adults have excellent records of never breaking a belt. Here is the reason why many kids break their belts,--- If you hop a curve, you must let go of the throttle. DO NOT have the throttle on wide open (full open) and hop a curve. If you do when the rear wheel comes off the ground, the rear wheel spins faster. When the scooter lands and the rear wheel hits the ground, you stop the tire from spinning, it will snap the belt. If you do hop a curve, let go of the throttle. When you land give it a little throttle. As you pick up speed then give it full throttle.
SOURCE: 50cc Two Stroke Scooter Engine - Poor Idle
I had the same problem- from out of nowhere the scooter started dying at every stop. I adjusted the idle screw to 2000 and it still idled up and down. I bought some injector cleaner but this will take a while to work (several tanks of gas) and then found this link- seems to be a very simple thing to do once you read this link. I hope it helps. --
Unfasten the kickstart by loosening the bolt head of the pin that attaches the kickstart to the outside of your scooter's variator case. This will allow you to pull the pin and remove the kickstart.
Remove the outer face of the variator system. On most scooters, this faceplate is attached to the variator case with six bolts.
