You posted under T1471BR timer.
This is a 4PST timer
Do not install photo eye on input voltage from breaker box, because that will stop timer clock from operating except nighttime, and then clock time will be off.
The timer clock terminals are A and B, so Connect white neutral to terminal A and black Hot wire to terminal B.
The terminal switch terminals are dry and receive no power when input terminal A and B have power.
Copy following link for illustration showing typical timer wiring.
http://waterheatertimer.org/images/T1471BR-wiring-500.jpg
Using illustration above: If You want to add photo eye, Remove black wire from terminal 5 to light bulb. Then Connect photo eye black wire to terminal 5, connect photo eye white wire to white wire at light bulb, and connect photo eye red wire to black wire at light bulb.
Copy following link for Intermatic T1400 series product manuals, 3-phase wiring, etc
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#T1400
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
