There is likely to be a problem with your machine 's components in the spin cycle that is triggering the circuit breaker in the main box. Have your machine checked / repaired / replaced. The circuit The
breaker should not trip if an identifiable problem has been rectified.
The fact that the problem only occurs during the particular part of the cycle indicates that there is possibly a problem with the
programmer at that part of the cycle, you may have a rotary programming/ mechanical programming knob?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Hi
The washing machine is obviously
drawing too much current for the breaker to handle. This could be due to the
washing machine drawing more that it should or because the breaker cannot
handle the current the machine needs, coupled with the other machines on the
ring main. If the fuse on the plug of the washing machine does not blow, then it
could be that there are too many appliances on the ring main. The fuse on the
machine may not blow however, if the breaker has a faster blow time than the
fuse in the plug. Try plugging the washing machine into another ring main. Or
try plugging out all the other appliances on the same ring main and test it
out.
If the ELCB (Earth Leakage Circuit
Breaker) is tripping only when the washing machine is running then something in
the machine is faulty.
One common problem is the heating element. Over time they tend to crack and
when the water gets in, the ELCB will trip out. This can be problematic to
diagnose as offten the element will only trip after a period of heating. Bottom
line, if it is tripping the ELCB then it is dangerous and should be fixed
before any further use.
Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
