Hi Terry:
As good luck would have it, I have one of these mowers.
As I see it, there are only two adjustments possible:
1) the for/aft positioning of the mower deck as determined by the length of the central front deck positioning rod.
2) the amount of tension on the spring that holds the engage idler against the belt. That can be changed by moving the bracket that anchors the spring.
I've had my unit for several years now and replaced blades, spindles, and pulleys (I mow far too many rocks) but never had to adjust the blade drive belt.
Hope this helps
