I had a Centennial washer on a service call doing this just the other day... After putting it trough diagnostics I found no errors and all the washer's mechanics tested okay. After resetting the control by putting it trough the diagnostics mode it continued to repeat cycles without restarting the washer.
Maytag Centennial Washer Diagnostic Guide
If it does turn out to be the control try contacting Maytag (Whirlpool) for a parts concession... Whirlpool customer service guide is linked below.
Hope that helps! Good luck!
SOURCE: Neptune TL will not spin
Check pump for blockage. Coins (quarters in particular) will block the discharge of water.
SOURCE: during the spin cycle, my maytag washer makes a
Hi
The problem most likely is something stuck in the water port of the drain pump.
The pump is located in the front right bottom of the machine and accessible by reoving the lower front panel, It is held in place by 4 small screws and is connected to the drain lines. Disconnect the plug for the outlet, then disconnect the power connection from the pump. Disconnect the drainlines after removing as much water possible from the drum as the water will come out of these liines when you remove them. Remove the pump, open the cover to see the impeller and hopefully the bobby pin, nail, screw, or whatever else is stuck there will be visible and easily removed. Put the pump cover back on, replace the drain lines and screws, and reconnect the power connection to the pump.
Thanks for contacting fixya.com
