Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
K
Ken Bowar Posted on Jun 16, 2015
Steering is screwed up. - Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
1helpful
2answers
How to remove the ignition lock cylinder from a 93 geo storm
is the lock assembly in the car or out?
there are 2 jobs here, removing the assembly
and after that, attacking the lock it self.???????
any lock smith can rebuild the lock, proper
it has pins that are pressed out.
it can even be rekeyed.
the remove assembly is covered in the FSM, no books?
alldata.com covers that.
it really is an Isuzu. impulse.
my guess is its job 1, assembly out.
so toss coin lands on job1
(on most cars, steering wheel must be removed)
once that is done, its obvious from there, right? that clamp there with the antitamper screws? then must be removed. and replaced new..
a rare car , and even more one that runs....
here is the online FSM answer
  1. Remove the negative battery cable.
  2. Remove the steering wheel.
  3. Remove the combination switch assembly.
  4. Turn the key to the OFFposition, depress the retaining pin and remove the ignition lock cylinder from the switch.
  5. Disconnect the electrical connector from the ignition switch.
  6. Remove the snapring and spacer collar from the steering shaft.
  7. Disconnect the back drive cable from the ignition switch.
  8. Remove the ignition switch bolts and the ignition switch from the steering column.
now back in?
  1. Install the ignition switch to the steering column and tighten the bolts.
  2. Connect the back drive cable to the ignition switch.
  3. Install the spacer collar and the snapring to the steering shaft.
  4. Connect the electrical connector to the ignition switch.
  5. Install the lock cylinder into the switch.
  6. Install the turn signal switch screws and the turn signal switch.
  7. Install the four screws and the coil assembly to the turn signal switch.
  8. Connect the coil assembly wiring harness to the turn signal switch.
  9. Install the two piece steering column cover and the two piece steering column cover screws.
  10. Raise the steering column and install the upper steering column mounting bolts. Tighten the bolts to 18 ft. lbs. (24 Nm).
  11. Install the left lower dash trim panel and tighten the lower dash trim panel screws.
  12. Install the lap air deflector and tighten the lap air deflector screws.
  13. Install the knee pad assembly and tighten the five screws, the bolt and the nut attaching the assembly.
  14. Install the engine hood opener cable.
  15. Install the engine hood opener and tighten the two screws.
  16. Connect the electrical connector to the cigar lighter bezel and install the bezel.
  17. Connect the electrical connector to the left switch bezel and install the bezel.
  18. Install the steering wheel.
  19. Connect the negative battery terminal to the battery.
that?
Steering column top bearing replacment
double posted, with 1999 added.
the FSM says dont reuse steering wheel bolts.. (unique)
here is an online quote to get to the combo switch
quote;
Removal & Installation
  1. Disconnect and isolate the battery negative cable. WARNING(bags can kill, my comment)
    Wait two minutes for the airbag system reserve capacitor to discharge before performing further diagnosis or service.
  2. From below the steering column, remove the three screws that secure the lower steering column shroud to the multi-function switch mounting housing.
  3. Using hand pressure, push gently inward on both sides of the upper shroud near the parting line between the upper and lower shrouds to release the snap features that secure the two shroud halves together.
  4. Remove both the upper and lower shrouds from the steering column.
  5. Remove the Steering Control Module (SCM) from the steering column.
  6. Remove the two screws that secure the left multifunction switch to the SCM .
  7. Disengage the two retaining tabs , next to the screw mounts that secure the left multi-function switch to the SCM.
  8. Disconnect the left multi-function switch from the SCM.
To install:
  1. Position the left multi-function switch onto position on the Steering Control Module (SCM) .
  2. Engage the two retaining tabs, next to the screw mounts that secure the left multi-function switch and firmly snap into place.
  3. Install the two screws that secure the left multifunction switch to the SCM. Tighten the screws to 22 inch lbs. (2.5 Nm).
  4. Position the lower steering column shroud to the underside of the steering column.
  5. Install the three screws that secure the lower steering column shroud to the multi-function switch mounting housing. Tighten the screws to 17 inch lbs. (2 Nm).
  6. Position the upper column shroud over the steering column with the hazard warning switch button inserted through the hole in the upper shroud.
  7. Align the snap features on the upper and lower shrouds and apply hand pressure to snap them together.
  8. Reconnect the battery negative cable.
1helpful
I NEED HELP REPLACING THE IGNITION KEY SWITCH ON A 1998 HONDA PASPORT ?
To remove the ignition lock:
CAUTION
You must remove the steering wheel when replacing the ignition lock. On vehicles with a Supplemental Inflatable Restraint (SIR) system, you must temporarily disable the SIR system and remove the inflator module when removing the steering wheel. Leaving the SIR system on could result in deployment of the air bag and possible personal injury.
  • Disconnect the negative battery cable, and remove the steering wheel.
  • Remove the bumper and the carrier snapring retainer from the steering shaft.
  • Use a lock plate compressor screw tool to install the lock plate compressor screw in the upper steering shaft. To keep the shaft from telescoping, tighten it to 40 inch lbs.
  • Using the lock plate compressor tool, install on the upper steering shaft, tighten it to depress the shaft lock. Remove the shaft lock retainer, the compressor tool and the steering shaft lock.
  • Remove the turn signal canceling cam assembly. Put the turn signal switch in the "N" position and remove the upper bearing spring.
  • Position the turn signal switch so the mounting screws can be removed through the holes in the switch and remove the turn signal lever.
  • Remove the turn signal switch-to-steering column screws and lift the turn signal switch. Remove the wire protector and disconnect the turn signal switch connector.
  • Use a terminal remover tool to disconnect the buzzer switch wires from the turn signal switch connector. Remove the buzzer switch assembly with needle-nose pliers.
  • Place the lock cylinder in the ACC position, then remove the lock retaining screw and the lock cylinder set.
  • To install the new cylinder lock, reverse the removal procedures.
  • Tighten the lock retaining screw to 22 inch lbs., the turn signal switch screws to 59 inch lbs. and turn the turn signal lever screw to 53 inch lbs.
  • As part of the final replacement procedures, check the operation of the switches and the steering column.
f42-11.gif The steering wheel is splined to the steering column and held in place by a nut. Courtesy of General Motors Corporation - Service Operations.
Highbeam switch
  1. If equipped, disable the SIR system. Disconnect the negative battery cable.
  2. Remove the upper steering column cover.
  3. Remove the lower steering column cover screws and lower the steering column cover.
  4. Remove the 2 switch mounting screws and remove the switch.
  5. Detach all wire connectors from the combination switch. Push locking tabs to remove the wires.
To install:
  1. Attach all wire connectors to the combination switch.
  2. Install the combination switch to the column with the 2 attaching screws.
  3. Install the lower steering column cover screws and lower steering column cover.
  4. Install the upper steering column cover and attaching screws.
  5. Connect the negative battery cable.
  6. Enable the SIR system, if equipped.
2helpful
Need to remove heater A/C dash control , what is proper procedure?
Look at fig. 4 for the heater a/c dash control: HEATER CORE Altima REMOVAL AND INSTALLATION
  1. Position the steering wheel in the straight-ahead position.
  2. Turn the ignition switch OFF.
  3. Disconnect the negative (() battery cable; then, the positive (+) battery cable. NOTE: Wait for a least 3 minutes after disconnecting the battery cables for the charge in the air bag circuit to dissipate before working on the air bag module(s).
  4. Remove the driver's side SRS and steering wheel by removing or disconnecting the following:
    • Lower lid from the steering wheel and disconnect the driver's air bag module connector
    • Left and right side lids from the steering wheel
    • Special bolts from both side of the steering wheel using a tamper resistant Torx wrench (T50)
    • Air bag module and store it face up
    • Horn's electrical connector and remove the steering wheel nut
    • Steering wheel from the steering column using a suitable puller
  5. Remove the passenger's side SRS by removing or disconnecting the following:
    • Glove box door and the glove box
    • Front passenger's air bag module connector
    • 2 special bolts using a tamper resistant Torx wrench (T50)
    • 4 passenger's air bag-to-instrument panel nuts
    • Front passenger's air bag module and store it face up.
  6. Drain the cooling system into a clean container for reuse.
  7. Discharge and recover the air conditioning system refrigerant.
  8. Working in the engine compartment, disconnect the heater hoses from the heater core tubes.
  9. Remove the instrument panel by removing or disconnecting the following:
    • Kick plate and dash side finisher on the driver's side
    • 2 lower panel-to-instrument panel screws and the lower panel on the driver's side
    • 2 lower reinforcement panel-to-instrument panel screws and the lower reinforcement panel
    • 6 steering column cover screws, the covers, the spiral cable and combination switch
    • 2 cluster lid "A" screws and the cluster lid "A"
    • 3 combination meter screws, disconnect the electrical harness connector and remove the combination meter
    • Switch panel
    • Instrument panel lower covers
    • Snap out the transmission shifter finisher (boot)
    • 4 cluster lid "C" screws and the cluster lid "C"
    • 4 audio and deck pocket-to-instrument panel screws and the audio and deck pocket
    • 5 center console screws and the center console
    • 2 center instrument panel screws and the center panel
    • front defroster grilles
    • Front pillar garnish
    • Instrument panel 3 nuts/4 screws and the instrument panel
    • 8 instrument stay assembly nuts and the stay
    • Steering member assembly 5 nuts/1 bolt and the steering member
  10. Remove the air conditioning housing assembly by removing or disconnecting the following:
    • Refrigerant lines from the air conditioning housing assembly
    • Thermo control amp
    • Air conditioning housing assembly
  11. Remove or disconnect the following:
    • Heater unit
    • Heater core from the heater unit Fig. 1: Exploded view of the steering wheel and air bag module 93112gd9.gif
      Fig. 2: Exploded view of the passenger's side air bag module 93112gd0.gif
      Fig. 3: Exploded view of the instrument panel assembly 93112ge1.gif
      Fig. 4: Exploded view of the heater housing assembly and related components 93112ge2.gif
      Fig. 5: View of the heater core and heater housing 93112ge3.gif
    To install:
  12. Install or connect the following:
    • Heater core to the heater unit
    • Heater unit
  13. Install the air conditioning housing assembly by installing or connecting the following:
    • Refrigerant lines to the air conditioning housing assembly
  14. Install the instrument panel by installing or connecting the following:
    • Steering member assembly and the steering member 5 nuts/1 bolt
    • Instrument stay assembly and the 8 stay nuts
    • Instrument panel and the instrument panel 3 nuts/4 screws
    • Front defroster grilles
    • Center instrument panel and the 2 center panel screws
    • Center console and the 5 center console screws
    • Audio and deck pocket and the 4 audio and deck pocket-to-instrument panel screws
    • Cluster lid "C" and the 4 cluster lid "C" screws
    • Snap in the transmission shifter finisher (boot)
    • Switch panel
    • Combination meter, connect the electrical harness connector and install the 3 combination meter screws
    • Cluster lid "A" and the 2 cluster lid "A" screw
    • Combination switch, the spiral cable, the covers and the 6 steering column cover screws
    • Lower reinforcement panel and the 2 lower reinforcement panel-to-instrument panel screws
    • Lower panel and the 2 lower panel-to-instrument panel screws, on the driver's side
    • Kick plate and dash side finisher, on the driver's side
  15. Working in the engine compartment, connect the heater hoses to the heater core tubes.
  16. Install the passenger's side SRS by installing or connecting the following:
    • 2 new special bolts and torque using a tamper resistant Torx wrench (T50) to 11-18 ft. lbs. (15-25 Nm)
  17. Install the driver's side SRS and steering wheel by installing or connecting the following:
    • Steering wheel to the steering column
    • Steering wheel nut and torque the nut to 22-29 ft. lbs.
    • Air bag module
    • New special bolts to both sides of the steering wheel and torque the bolts using a tamper resistant Torx wrench (T50) to 11-18 ft. lbs. (15-25 Nm).
    • Both the left and right side lids to the steering wheel
    • Lower lid to the steering wheel and connect the driver's air bag module connector
  18. Refill the cooling system.
  19. Connect the positive (+) battery cable; then, the negative (() battery cable.
  20. Evacuate, charge and leak test the air conditioning system refrigerant.
  21. Operate the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
12helpful
How to replace the multifunction switch of a 2006 Dodge Ram
REMOVAL
WARNING: To avoid serious or fatal injury on vehicles equipped with airbags, disable the Supplemental Restraint System (SRS) before attempting any steering wheel, steering column, airbag, seat belt tensioner, impact sensor, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the SRS. Failure to take the proper precautions could result in accidental airbag deployment.
2. Remove the screw (2) that secures the tilt steering column knob (1) and remove it from the tilt actuator (3) on the left side of the column.
3. From below the steering column, remove the two outboard screws that secure the upper column shroud (1) to the lower shroud (3).
4. Using hand pressure, press inward on both sides of the upper shroud above the parting line of the lower shroud to release the snap features that secure the two shroud halves to each other.
5. Remove the upper shroud from the lower shroud and the steering column.
6. Remove the one center screw that secures the lower shroud to the steering column (4).
7. Remove the lower shroud from the steering column.
8. Disconnect the wire harness connector (2) from the back of the multi-function switch housing (1).
9. Rotate the steering wheel far enough to access and remove the two screws (4) that secure the switch to the multi-function switch mounting housing (3).
10. Grasp the switch control stalk and pull it toward the left side of the vehicle to remove the switch from the mounting housing.
INSTALLATION
1. Slide the multi-function switch (1) into the multi-function switch mounting housing (3) from the left side. Be certain that the alignment pins on the top and bottom of the switch are properly engaged in the channels of the mounting housing.
2. Rotate the steering wheel far enough to install and tighten the two screws (4) that secure the switch to the mounting housing. Tighten the screws to 2 N·m (20 in. lbs.).
3. Reconnect the wire harness connector (2) to the back of the switch housing.
4. Position the lower shroud (3) onto the steering column (4).
5. From below the steering column, install and tighten the one center screw that secures the lower shroud to the steering column. Tighten the screw to 2 N·m (20 in. lbs.).
6. Position the upper shroud (1) onto the steering column over the lower shroud. On vehicles equipped with an automatic transmission, be certain to engage the gearshift lever gap hider into the opening in the right side of both shroud halves.
7. Align the snap features on the upper shroud with the receptacles in the lower shroud and apply hand pressure to snap them together.
8. Install and tighten the two outboard screws that secure the upper shroud to the lower shroud. Tighten the screws to 2 N·m (20 in. lbs.).
9. Position the tilt steering column knob (1) onto the tilt adjuster actuator (3) on the left side of the steering column, then install and tighten the screw (2) to secure the knob to the actuator. Tighten the screw to 2 N·m (20 in. lbs.).
10. Reconnect the battery negative cable.
How do you remove the ignition lock cylinder on a 1991 chevy cavalier
The ignition switch removal and installation procedure is given in , under steering, because the steering wheel must be removed for access to the ignition switch.
CAUTION
Hope this helps (remember rated and comment this).
1helpful
2006 hhr to take out ignition switch out
1. Disable the SIR system.
Remove the Instrument Panel (I/P) center trim panel by releasing the retaining fasteners
  1. Remove the Instrument Panel (I/P) center trim panel (1) by pulling out on the trim panel in order to release the retaining fasteners (2).
  2. Disconnect the electrical connectors on the Instrument Panel (I/P) center trim panel (1).
Remove the steering column opening filler assembly, with clip, & bumper
3. Remove the steering column opening filler assembly (1) by pulling away the clips (2).
4. Disconnect the electrical connector for the trunk release.
Remove the Instrument Panel (I/P) left side trim panel
  1. Remove the Instrument Panel (I/P) left side trim panel (1).
  2. Tilt the steering wheel up.
  3. Disconnect the I/P dimmer switch and, if equipped, the fog lamp switch.
Remove the 4 bezel screws (2) & the Instrument Panel (I/P) cluster bezel assembly (1)
  1. Tilt the steering wheel down.
  2. Remove the 4 instrument panel cluster bezel screws.
  3. Remove the instrument panel cluster bezel.
Remove the steering column trim covers: steering column upper cover assembly, steering column left cover assembly, & steering column right cover assembly
  • Remove the 3 cover screws (4).
  • Remove the steering column upper cover assembly (1).
  • Remove the steering column left cover assembly (2).
  • Remove the steering column right cover assembly (3).
Removal of the ignition switch
    1. Disconnect the ignition switch harness connector.
    1. WARNING
    The ignition switch must be in the run position during removal in order to avoid damage to the ignition switch.
    1. Turn the ignition switch to the run position.
    2. Remove the ignition switch screws.
    3. Remove the ignition switch from the steering column.
    To install:
    1. Install the ignition switch and screws on to the steering column. Tighten the screws to 17 inch lbs. (2 Nm).
    2. Connect the ignition switch harness connector.
    3. Installation is the reverse of removal procedure.
    4. Tighten the trim cover screws to 17 inch lbs. (2 Nm)
    5. Tighten the 4 instrument panel cluster bezel screws to 19 inch lbs. (2 Nm)
    6. Enable the SIR system. Refer to Air Bag (Supplemental Restraint System), arming the system.
      NOTE If the ignition switch is replaced and a learn procedure is not performed, the engine will crank but not start or will start and stall immediately.
    7. Perform the vehicle theft deterrent system learn procedure.
    1helpful
    Do you have the steps to replace the pump
    Notes Power steering pump, replacing
    Note: As the illustrations in this service information are used for different model years and/or models, some variation may occur. However, the essential information in the illustrations is always correct.
    Preparation
    Warning: Used fluid is considerably more dangerous than new fluid. Avoid skin contact with the oil.
    Remove
    • the oil hose from the mounting on top of the power steering pump
    • the auxiliaries belt.
    Note: If there is dirt in the fluid, drain the system and remove the hoses from the steering gear.
    Removing the power steering pump/engine strut
    Applies only to diesel cars:
    Remove
    113652509
    • the screw at the pump
    • the screw at the engine.
    Leave the strut hanging in the delivery line.
    Removing the feeder hose and delivery line
    Install
    113652510
    • the lock grip pliers on the feeder hose as close to the power steering pump as possible
    • the lock grip pliers on the return hose at the fluid reservoir.
    Note: Place paper over the generator (GEN) as protection against oil.
    Remove
    • the screw nipple. Remove the delivery line from the pump
    • the hose clamp. Remove the feeder hose from the power steering pump.
    Warning: Avoid skin contact with the oil.
    Remove
    113652511
    • the 3 screws
    • the servo pump.
    Installing the power steering pump
    Install
    • the servo pump
    • the three screws. Tighten to 25 Nm .
    Install
    • the feeder hose. Tighten the clamp
    • the delivery line. Do not tighten yet.
    Installing the power steering pump/engine strut
    Install
    • the strut
    • the screw at the engine. Tighten to 24 Nm
    • the screw at the pump. Tighten to 24 Nm .
    Finishing
    Tighten the delivery line. Tighten to 25 Nm .
    Remove paper and lock grip pliers.
    Install the auxiliaries belt.
    113652512
    1helpful
    1976 Maverick and the steering is too loose. May be the gearbox, can it be adjusted?
    Yes it can, on top of the steering gear box there is a locking nut with a screw in the middle of it, loosen the lock nut and with a common screw driver turn the center screw in, clockwise for tighting steering and counter clockwise to loosen steering. That will take out what they call the play in the steering wheel.
    Top Minn Kota Boating Experts
    ADMIN Andrew
    ADMIN Andrew
    john h
    vince
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
