Try this link
it says the following:
E13
Condition
Water leak in the tub or air leak in pressure-switch air hose
Check/Repair
The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts
Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
