SOURCE: need free code to unlock blackberry 8220 flip
No guarantee, but try --
You must OWN your BlackBerry out right. Have your IMEI# available. If applicable, on your BlackBerry, dial *#06# to retrieve your IMEI#. Contact your service provider. Ask for a BlackBerry Data Support Representative. Explain why you need Unlock Code (ie: need to use your phone out of the country).
Good luck! ~ :)
SOURCE: blackberry 8100 master unlock code(phone code problem)
Go to http://blackberrymep.com and get your unlock code (MEP code) .
SOURCE: i forget my mobile password
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*7673# = Sleep mode RESET
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
*2767*73738927# = WAP Settings Reset
Try at your own risk .. i can't guarantee !!!
SOURCE: my blackberry pearl flip 8220 cellular phone not working
hello,it is a flex problem that mainly occurs to flip phones as a result of various opening and closing of the flip.all you need to get is a new flex to fix up the faulty one.you can kindly take it to an authorized expert to fix it up for you if you are not electronically inclined.and also it could be a affect the inner screen soonest if not attended to immediately.it could also be that the outer screen is bad so after the flex is replaced if the screen still does the same then you will need to fix up the screen.
please kindly rate this solution if it's helpful,
take care.
SOURCE: i need unlocking code for
Hi try here http://www.theunlockarena.com/blackberry-8230-pearl-flip/rs13wp9/ to get unlock code for your mobile and get it unlocked..
