SOURCE: Bosch dishwasher shu4322 has code 1 aqua sensor what is the sensor do and where is it located
Most of the dishwasher has a Thermal hold period in which the machine will not advance to the next cycle until the water temperature reaches a specific degree. it is possible that your aqwa sensor/or heater is bad OR as in most of the cases, the Timer relay that is responsible in turning the heater on is stuck open, in this case you need a new timer. So,Check Timer/Aqua sensor/Heater
SOURCE: Asko D3350 code F7
Just click below;
WHAT IS WRONG WITH YOUR DISHWASHER?
For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Regards,
VOTIT
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
SOURCE: 2H displayed and pump runs nothing else happens
I, along with many others online, are experiencing the same problem. The bottom line is the control panel needs to be replaced. Beware, though, that the replacement panel may also be bad as I've seen many reports that they are poorly designed and Bosch isn't doing anything about it.
There are 2 things I'd like to clarify...
1) The display "2H" is an error code which, according to Bosch, indicates service is needed on the unit. The code is different from "2h" (note the lower-case letter h), which is what would display when the delay start button is pushed.
2) The number 1 showing at the "end" of the cycle does NOT mean 1 minute left. It is a 2nd error code indicating the unit has "timed out."
I'm waiting to have my control panel replaced a second time. The first repairman from Sears replaced the control panel with a refurbished one, but the unit still showed 2H. He was about to leave when I told him the problem wasn't fixed. He tried to tell me that the 2H meant the cycle would be longer than 2 hours because my water temperature was too low (it is at 120 degrees, the proper temp per Bosch). He said I needed to increase my water temp or else live with the fact that the dishwasher would take a long time to run through the cycle. I asked him to call Bosch and he said they wouldn't talk to him (he really had an attitude). I asked for a receipt (on which he commented the "dw works fine") and, after he left, I called Sears back to get a "senior" technician out to fix it. They ordered another (new) control panel for me and they'll be out this Friday to (try) to repare the unit. Hoping this time it will work.
SOURCE: My dishwasher Whirlpool ADP 533-1, no heating the
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
